map sensor issues on DBW, has this happened?
Old Oct 29, 2009 | 10:06 PM
lewiS2K's Avatar
Default map sensor issues on DBW, has this happened?
having issues with car idle/performance. . .
All the symptoms are identical to the notorious ap1 MAP sensor problems.
When I look at the map sensor on my DBW and the map sensor on an older ap2/ap1, they are completely different.
Are they essentially the same?
Has anybody had issues with their DBW Map sensors?
Thanks in advance.
Also, I pulled the MAP off and noticed that there were some crusty oil deposits on the inside of the map, is this common? does that mean its time to replace the MAP?
Old Oct 29, 2009 | 10:08 PM
OMG VTEC's Avatar
I've never heard of this on the 06+. I did have this problem with my 03.
Do you have an aftermarket intake system?
Old Oct 30, 2009 | 01:36 AM
macr88's Avatar
Lewis, it's most likely from blow by, take a picture of your pcv setup and send it to me. Not sure how to clean it, I know maf's are very sensitive and need to be cleaned carefully but I've yet to clean a map sensor.
BTW this is where you should have posted this
I shouldn't be posting in here with my NA badge hehehehe.
Old Oct 30, 2009 | 06:29 AM
spectacle's Avatar
Clean it and the passageway with brake parts cleaner and see if it helps.
Old Oct 31, 2009 | 04:40 PM
lewiS2K's Avatar
is it a good idea to spray MAF cleaner into the manifold where the sensor mates into?
Old Nov 1, 2009 | 04:10 AM
spectacle's Avatar
Yea, just clean as much of it out afterwords.
Old Nov 1, 2009 | 02:13 PM
lewiS2K's Avatar
k thanks!
Arian
Jun 7, 2012 11:57 PM
h4mmer
Apr 16, 2012 01:53 AM
trivium
May 22, 2007 05:15 PM
SCA S2K
Sep 18, 2006 01:56 PM
F1s2000
Dec 12, 2003 01:57 PM
