MAP sensor necessary?
Just curious as to if I am running 12-15psi of boost with an inline pro kit and 3mm HG if I should change the MAP sensor. And if I do need one where is the best place to find it and best spot on the vehicle to install it.
I have done a few searches but they were fairly old posts. Thanks
What are you using to tune?
If you have an emanage with pressure sensor, then no you won't need one.
If your using the AEM EMS (that uses the stock map sensor) you'll need one.
I think the rule of thumb is like 12psi+ you'll need a new sensor.
Originally Posted by ChefJ' date='Mar 24 2007, 09:32 AM
I don't have the optional pressure sensor. Is it compatible to the emanage blue if so where can I find it?
ScienceofSpeed
Jan 24, 2011 01:17 PM
