map sensor! and stock exhaust
Old Apr 29, 2008 | 07:24 PM
03silver2000's Avatar
Default map sensor! and stock exhaust
can i use my stock catback with my turbo setup im shootin for 500hp with 3mm headgasket el manifold ect. i have a invidia test pipe will i be able to hit 500 with my stock exhaust?
please if someone could have a def. answer to this cause now im nervous cause i dont wana upgrade my exhaust i like the sleeper look
ive heard of people getting dynod with stock exhaust and its like hitting a brick wall at 7000 rpms and it gets me nervous now what?
DO I NEED A AFTERMARKET MAP SENSOR WITH MY AEM EMS 1052? such as a aem 3.5 bar or a gm 3 bar
Old Apr 29, 2008 | 07:59 PM
help please
Old Apr 29, 2008 | 08:22 PM
skibum's Avatar
It's going to kill your performance. Go with a 3". No point in spending all that $$$$$ on a turbo kit and not reap full benefits over a few hundred dollars.
Old Apr 30, 2008 | 01:03 AM
mugenrsx's Avatar
The stock exhaust is gonna choke the hell out of a 500hp motor.
Get a custom exhaust and have the stock tips welded on.
Old Apr 30, 2008 | 06:56 AM
TRBOKEV's Avatar
at least get a 70 mm exhaust.
There is no such thing as a 500 HP turbo motor with a stock exhaust (Unless you can put one of those valves that you can push a button and it opens goes strait pipe)
Old Apr 30, 2008 | 07:00 AM
Revenge's Avatar
If you want an exhaust that looks like stock for a turbo get a 3" dual from Ultimate Racing. And yes you will need to upgrade.
Old Apr 30, 2008 | 08:34 AM
MrSmith's Avatar
The more power you are trying to make the bigger the restriction becomes. If you want the sleeper look go with a dual setup with stock looking mufflers and stock tips. If you are catted/resonated it should not be too loud.
The 3 inch dual from UR, just needs the mufflers painted black:
Old Apr 30, 2008 | 12:52 PM
73Zero's Avatar
The UR exhaust (or one similar in appearance) would be perfect for the sleeper look
Old Apr 30, 2008 | 06:35 PM
bump
Old Apr 30, 2008 | 07:02 PM
ZSAK's Avatar
a map sensor is needed if you are going to boost over 10lbs which in your case for 500hp you certainly will.
