Mase Engineering S2000 Turbo Kit
Old Mar 20, 2010 | 11:00 AM
MaseEngineering's Avatar
Banned
Default Mase Engineering S2000 Turbo Kit
This past year has been a very busy one for us at Mase Engineering. We successfully launched products in a few different platforms, the most notable for this forum being the s2000 Turbo Kit. Thankfully we were blessed with many orders, and we are now happy to say we are caught up on our backlog.
Beginning now, we are officially releasing the Drive By Wire Turbo Kit for the s2000s. This includes 2006-2009 models. We now support a turbo kit for every single s2000 model, whether it be USDM, EURO,JDM, ETC. We have a turbo kit for every type of s2000 all across the world.
What sets us apart from the rest:
You DO NOT have to relocate anything with our turbo kit. Many turbo kits require you to relocate batteries, fuse boxes, ac lines, oil filters, etc and some require you to do additional fabrication to finish their installation procedure. Many Supercharger Kits have belt slippage and other problems as well (not to mention they don’t make the power of the turbochargers). All of that can lead to many headaches and hardships that just are not needed with our kit. Our kit is the only true complete and virtually bolt on turbo kit. It comes with some of the best components made to make up a complete turn key very powerful turbo kit.
Speaking of power, we’ve posted a blog comparing our turbo kits to other kits on the market.
Link:
http://maseengineering.com/blog/entry/s200...kit_comparison/
Pricing. Heres another subject on everyones mind. Our kit comes with everything you need, Yes EVERYTHING (besides a clutch). You don’t have to go out and buy additional expensive fuel management systems, nor do you have to pay for additional fabrication to finish up the exhaust, or pay the mechanic to relocate any of your fusebox/battery/oil filter. When shopping for turbo kits, make sure you add up all the costs.
What about for built motors? Our kit is good for stock and built motors. We give you the option on turbo selection. Here is a dyno chart of a built bottom end 2.2L we recently did: (25 psi billet 6262 ball bearing race gas)
What if I already have a kit?! Well we are getting an increasing amount of interest about purchasing only certain parts of our turbo kit. We will be happy to work with you if you have an exisiting kit and want to purchase only certain parts of our kit. Please email for pricing as it will always be different. Special Note, there will be a lot of variance depending upon what you start with if you are not purchasing all of our kit.
The Kit Includes:
Mase Engineering Turbo Manifold/Downpipe/Wastegate Dump
Manifold Made from Schedule 10 thick walled Stainless Steel
Downpipe made From 16 Gauge 304 Stainless Steel
Designed with V-band clamps
Mase Engineering Specified Precision High Flow Intercooler
Bar & plate construction - Garrett Core
Extremely Dense to ensure maximal cooling
Mase Engineering Specified Precision Turbo
Specifically chosen for a well balance of power and transient response, quick spool.
(Turbo Options available)
Tial Wastegate and Blow off Valve
Mase Engineering Intercooler Piping
Aluminum construction saving weight and proper heat dissipation
Mandrel Bent for optimal flow
Bead rolled and T-Bolt Clamps Included
Engine Management and Fuel Setup
AEM EMS Pre-Tuned Calibration tuned by Mase /DBW cars receive Hondata Flash Pro w a tuned calibration (Hondata KPro Available for an additional cost for 2000-2005 models).
725cc Injectors with plug and play clips (no resistor box or extra wiring needed)
255 lph High Pressure Fuel pump
Plug and Play 4 bar Map sensor
Boost Controller included and integrated
Mase Engineering Hardware
All hardware is included that is needed to complete the install. Detailed
instructions will be included. 3 Year Warranty against manufactured defects. 1 Year warranty on turbocharger.
Options Available.
Engineered to not only fit without having to modify anything significant, but makes unbelievable power. Again, You DO NOT have to relocate the battery, oil filter, fuse box, etc. These kits are designed for 100% Stock Engines but work well on built motors as well.
This is the only kit on the market that is 100% complete, bolt on 400 whp+ capability out of the box. ** Actual Power output will vary depending upon many factors.** Larger Exhaust recommended
You will need an upgraded clutch.
Price- $6995 for non drive by wire models. $6695 for DBW models. FREE SHIPPING (within the 48 states) on the full kits. Deposit Required. For orders or other questions, please email Mase@MaseEngineering.com
Old Mar 20, 2010 | 12:55 PM
dsddcd's Avatar
Very Nice, but when are you going to send mine so we can do a back to back compairison to the IP cast manifold?
*Edit*
Kit is on order
Old Mar 20, 2010 | 03:31 PM
Harpoon's Avatar
Do you think there is a measurable difference in power between the DBW turbo cars and the non-DBW turbo cars?
Old Mar 20, 2010 | 03:54 PM
ILoveMYHonda1984's Avatar
Thats some really nice torque numbers you have there. Looks like a very good option for the DBW cars. Mase = Greatness
Old Mar 20, 2010 | 04:26 PM
soulicious's Avatar
PM sent for pricing!
Old Mar 20, 2010 | 04:38 PM
Mrfixit687's Avatar
I hope my SOS street clutch can hold this power.
Old Mar 20, 2010 | 08:14 PM
stitos2k's Avatar
I think it can, but I wouldn't go dropping the clutch 3 times a day every day. Then again maybe not, I just read its good for around 260 wheel tq.
Old Mar 20, 2010 | 11:06 PM
turbociv910's Avatar
finally mase posted real numbers for his turbo kits.
not some 550whp on 12 psi on a 3076r.
good job.
Old Mar 20, 2010 | 11:27 PM
Chow-bot's Avatar
are we able to buy the kit with out fuel/engine management?
Old Mar 21, 2010 | 11:52 AM
Mrfixit687's Avatar
Is the flash pro able to control the boost?
