max boost on stock head gasket
Old Feb 2, 2010 | 11:24 AM
Colt45's Avatar
Default max boost on stock head gasket
I recently had my car dyno tuned, It put down 344hp, 226tq. peak power was around 7500 rpms. The boost was a wastegate/8psi. It was tuned conservatively afr in the low 11s.
Im thinking of turning up the boost to 10psi to get closer to 400hp. Would that be safe?
setup: comp stg 5 clutch/pp/fly, sc61 with ported cover/63 exh housing, walboro pump, 1000cc bosch injectors, aem ems, sidewinder style manifold, 3 inch open downpipe. stock motor with 40k
ive researched mult threads with 10+ psi, but didnt find anything on how long it lasted.
thanks for your input.
Old Feb 2, 2010 | 11:47 AM
TRBOKEV's Avatar
perfectly safe with a good tuner IMO.
DO IT!
Old Feb 2, 2010 | 12:21 PM
camuman's Avatar
very safe. i run 10psi SC on my stock hg with zero concern. people have run WAY more with no problems. psh if i had your setup i would crank it to 450+whp on pump and call it a day. i run similiar power to you and i feel like i am standing still sometimes
Old Feb 2, 2010 | 02:42 PM
Revenge's Avatar
yeah I think you could add 2-3 more psi you may want to get a AEM map sensor. I think it would last just fine as long as you don't beat on it every day
Old Feb 2, 2010 | 03:04 PM
freshs2k's Avatar
I'm doing 18psi with water meth boost juice.
Old Feb 2, 2010 | 03:10 PM
s_d2k's Avatar
im running 19 psi on stock hg with w/m injection .
Old Feb 2, 2010 | 04:24 PM
Spec_Ops2087's Avatar
Do whatever your tuner is able to do, pushing it past HIS limit is what destroys motors.
Old Feb 2, 2010 | 04:59 PM
Colt45's Avatar
He will run more, he's tuned multiple s2ks. Also I have a gm 3 bar map
Old Feb 2, 2010 | 06:11 PM
Momentum's Avatar
might want to specify fuel
Old Feb 2, 2010 | 06:17 PM
boostedf22c's Avatar
I don't think there is "max boost" number for a stock headgasket.
They are good gaskets, and hold up to tons of boost.
