Max Impeller speed
Old May 3, 2010 | 07:30 PM
lvd1102's Avatar
Default Max Impeller speed
just wondering what the max impeller speed for the Novi 1000 ap1 redline 9000rpm is. Right now im using a 3.875 pulley. just wondering how much smaller i can go before i hit that max. and what boost would that give me
Old May 3, 2010 | 09:59 PM
SRap1's Avatar
i think its around 12-13 psi... but its more so the fact that the pulley's get too small and can no longer grip the belt so they slip.
whats that 3.875 pulley giving you?
I have the same pulley but havent installed it yet.
Old May 4, 2010 | 02:38 AM
lvd1102's Avatar
Well i have a UR FMIC and its putting down 6.2psi. i think its a 9lbs pulley.
Old May 4, 2010 | 07:51 AM
deathsled's Avatar
the 3inch pulley spins the novi 1000 to its limit (around 55k rpm I think) with a 9k redline when using the comptech kit. You can use the 2.8 pulley if you redline at about 8.
Old May 4, 2010 | 06:07 PM
RAIN H8R's Avatar
that is true.... Im running a 3.2 that nets 11-12 psi. Im looking to go 3.0 if I ever get a J's Header and J's 70RS
Old May 4, 2010 | 07:10 PM
lvd1102's Avatar
with the 3.875 pulley and ur fmic i got 6.2psi. trying to net about 9lbs its either that or find an aftercooler
Old May 5, 2010 | 02:03 PM
deathsled's Avatar
I would totally go for the 3.2 or even the 3.0 pulley in your case then. I assume you're going to be tuning for it anyway and will have injectors and ems by that point, so why not?
s2kseven
Jun 13, 2019 11:17 AM
july7543
Jul 17, 2010 12:55 PM
kylemonster85
Jun 11, 2007 10:26 AM
BahrainONE1
Sep 12, 2005 06:58 PM
