Maxing out my current gtx3076 setup
I maxed out my gen 1 gtx3076r at 588whp on E85 at 20psi. I run a walbro 450pump with id1300cc injectors. 60psi base fuel pressure. Injectors were close to maxed out.
I always advise people with street cars that care about drivability to stay away from injectors larger than the id1300. 2000cc injectors drive like crap. I started with id 2000 the. Went down to the fic 1650 and I couldn’t be happier with my perfect drivability Id13000.
yea, but how long do you want it to last? you can dyno 900whp on stock block, i think neema or someone before has already accomplished it but its not going to last. if you're just reaching for the stars as far as hp numbers go thats one thing, but if you want a solid somewhat reliable turbo s2k, i would stay under 650whp.
you're already making good power, just try to be happy with what your tires can handle on the street. im already fighting traction with 255 120tw tires at 500whp. I have my boost by gear set at 16psi in 3rd and i see the full 500whp (18psi) in 4th gear on. I cant even go full boost in 3rd i'll break loose my tires. im pretty happy with where its at at the moment. i may get the five-o 2200cc injectors down the road just for head room and turn up the boost to make 550whp.
I'm actually considering getting custom rpf1s to run 305 tires on stock body for more traction. Im not sure what the max psi capacity is on the s2000. Ive seen evo's go up as much as 40psi but never seen an s2000 run that much boost. i dont see why you cant just up the boost towards 30psi on a 3076r... maybe theres a reason why people dont push that much boost on this turbo?
how are you doing with traction?
wouldn't the 2000cc be over kill tho for 600-650whp. I am only looking to max out my stock block gtx3076.
Thinking about running either toyo r888 275r4017 or my et street radials as tires also...
Broooo I'm heading to import Auto pros to see Dave and returning on 1600cc injectors and max boost on 3bars and single fbm340 fuel pump. Wish me luck and max hp kaka
