Meth Injection and tune
LOL
Yes you can run it but your car will run RICH without a tune.
Do some research, there is a TON of stuff on the internet and it seems that at least half of who replied to you have zero clue about WATER/Methanol injection.
Generally this is how I would do it.......especially if you're not using an EMS with multiple maps:
Run a boost controller with your "high" setting as your methanol setting. Tune the boost accordingly on the dyno with the meth, see what you can get away with in terms of a boost increase without making the afr's too dangerous.
It's an easier way to up the boost and get more power without having to completely retune the fuel map as well for the meth/boost increase.
And to activate the meth, use a boost sensor. When it hits x psi, methanol injects.
that is how mine is rigged up
Originally Posted by Soul Coughing,Sep 10 2008, 01:35 PM
do you have any safegaurds to lower the boost if the methanol isnt flowing?
Of course, you could have a "low level" indicator so that when the meth level reaches a certain point, an LED kicks on somewhere.
