Which Meth Kit to get?
Old Apr 5, 2012 | 02:07 PM
indi00's Avatar
Default Which Meth Kit to get?
I've been doing some readings on meth kits.
I have the Ptuning kit GTX3076 on 91oct at 13psi with timing in between 11-12 with less than 1.5volts knock volts.
I would like to get some insight on which meth kit should I get...I will be using this with the AEM EMS V2.
I was thinking of just getting the basic AEM meth kit for $375.
Cooling mist have their EMS failsafe kit for $499
http://www.coolingmist.com/pagedispl...key=turbo_kits
And then, do I really need all the functions of the new Aquamist HFS-3/HFS-4 appx $1000?
http://www.howertonengineering.net/p...on-System.html
decisions, decisions....
Old Apr 5, 2012 | 03:21 PM
japhethwar's Avatar
I've just started using the Aem myself recently. I opted to get the flow monitor guage setup as well. Its nice because you can set parameters with the flow to trigger failsafes and the like. I have it wired to my truboost to automatically engage the scramble boost mode and drop it to wastegate pressure only in the event of a flow failure. Unfortuneatly though I have had a few issues with the flow sensor jamming falsely dropping the boost. It seems my sensor is bad and it is currently on the way to cali for them to inspect and replace. I like the simplicity of Aem's system and when working properly the flow guage and failsafe monitor do an excellent job. The only other real issue i've had is with the pushlock fitting. I have removed the flow sensor from the line multiple times and it seems that the hose wears out if you remove and replace it very often. I had the line blow off the sensor at the dragstrip the other night after an aggressive burnout. Problem was solved by cutting about 1/2" of the line off and reinserting a fresh end into the sensor. All in all the Aem seems to be decent stuff, but like anything performance wise it does add yet another failure point that must be monitored constantly. I find myself almost glued to my guages now, and I am constantly checking for problems. Which, I guess you should do anyway. It is worth the hassle though. The power increase is amazing for just a few hundred bucks, and a retune of course. Evan's was able to increase my boost to 18psi with 93 and 50/50 w/m. I was running 13ish without.
Old Apr 5, 2012 | 03:22 PM
siadam's Avatar
Anything less that 600 the single nozzle aem kit is more than sufficient.
I'd suggest the flow gauge to go with it though.
Sent from my iPhone 4 using Tapatalk.
Old May 20, 2017 | 02:08 PM
nguyen365's Avatar
I know this post is like a million years old but I saw Evans tuned a 2006 with ptuning gtx3076 19_20 psi on 50/50 water meth at 550whp. Does anyone have similar results. I have ordered the flex fuel sensor and there's a e85 gas station in Bakersfield now but do not like the thought of having to refuel every 2 days.
Old May 20, 2017 | 03:10 PM
MorngWoodStewie's Avatar
You'll go through the meth even quicker.
I don't think you could save money using a ton of 50/50 over E either.
Old May 20, 2017 | 03:44 PM
nguyen365's Avatar
maybe save money and just retune on 91 octane at 13 psi? Stock block install flex fuel sensor at 20 psi?
Old May 20, 2017 | 05:22 PM
I'm usually not one to talk, cause I get going and then have to proof read for an HR lol. But I'm not sure if I understand what ur saying or asking.
You will need a re tune once u install ur E sensor. If you want the E potential, obviously it's just reading content without the computer saying add this n that it's not gonna do anything.
R u not tuned on pump yet?
Old May 22, 2017 | 06:13 AM
nguyen365's Avatar
yes I'm currently tuned on 91 octane at 11.5 psi. Just deciding between e85 and water meth now
Old May 24, 2017 | 12:18 PM
minubaba's Avatar
I am located in NJ.... don't even feel like e85 is a option... where the hell would I buy gas? there are like 3 stations in the whole state...
Old May 24, 2017 | 03:03 PM
LostMarine's Avatar
Depending on which is closer to you. I know both owners and use both. I keep 40 gallons of E at my house at all times
https://www.facebook.com/omegafuels
https://www.facebook.com/racefuelnj
TheMuffinMan
Sep 1, 2014 10:21 AM
S2K Tuning
UK & Ireland Traders Forum
Dec 18, 2013 10:27 AM
westys2k
Oct 22, 2011 09:18 AM
PanosS
Περιοχή μόνο για μέλη
15
Jul 21, 2009 07:35 AM
