Methanol/water injection
Old Feb 2, 2007 | 07:23 PM
TheCarGuy2021's Avatar
Default Methanol/water injection
I was doing some research online today about ethanol(alcohol)/water injection and was reading how people use an EMS/fuel/timing computer to tune appropriately for the methanol/water injection. I was curious if I would be able to add a kit without using an EMS to tune it. I read that the fuel is made a little more lean, and that the timing is advanced to accomidate ethanol/water injection. Would it be possible (safe) for me to just remove the Vortech timing box to get a few degrees back in advance, and switch back my FMU to a 10:1 rising rate (it's at 12:1 now)? I would plan on using a rising rate ethanol/water injection kit dependant on boost. Just wondering, for what you could have for the price of a cold air intake (which yields very little gains), you could have this kit which would run much lower intake temps and be the "equivilant" of a higher octane, higher quality fuel.
Any thoughts welcome...
Old Feb 2, 2007 | 07:56 PM
pushin9's Avatar
Yes you sure can. You can use a boost pressure switch. This will allow you to set the switch to activate the water/meth when you hit a preset boost level. For example you can set it to 1psi. So once you get into boost your water/meth would turn on and stay on when in boost, then once you drop back below your preset level (in this case 1psi) the water/meth would turn off.
Just so happens I have one of these switches laying around from when I had my water/meth injection hooked up this way if you want to buy it send me a pm.
here is the switch I have
Old Feb 2, 2007 | 08:10 PM
Cool, I'll let you know. I was also reading up on how some of the newer kits use a rising rate velocity based on boost. Those are $$$ though, so I will probably use a switch like you stated if/when I decide to get a kit.
How do you like your kit? Pros/Cons? Anything to worry about/be concerned about?
Old Feb 2, 2007 | 08:17 PM
pushin9's Avatar
Well funny story kind of
Old Feb 2, 2007 | 08:21 PM
So no need for new engine management?
killerbee_vr6
Nov 11, 2015 12:47 PM
Moddiction
Oct 24, 2014 02:58 AM
SFV_S2k
Jul 5, 2009 07:17 PM
krazik
Jun 30, 2004 09:50 AM
