Misfiring at high boost
Also 7173 coppers are NOT resistor plugs and can cause misfires, or interference with other electronics such as radar detectors, like in my experience. Get those NGK 2668's!
what is your A/F like in that area? I had the same issue so I bumped my old thread up for you to help out.
You should ditch the 7173's. I switched to those from the iridium 8's a while back and had major misfire issues; switched back to the iridium 8's and it was gone. I'll never run another copper plug again; especially the 7173's.
That's happening because you are throwing all the fuel to the back of the tank when you take off if it's below a 1/4 tank and the pump is cavitating and pulling in air.
