Mocal sandwhich plate thermo question
Old Jul 15, 2016 | 05:14 AM
chefs2000's Avatar
Default Mocal sandwhich plate thermo question
Hey guys posting here as well as in under the hood ... Well my question is .. I installed the mocal sandwhich plate with a thermostat not sure what temp yet ..ran to a setrab oil cooler .. So I filled the car with oil and ran it .. Right away oil went into cooler .. I added additional quart .. Ran again to try to get to temp and see if thermostat opens .. But it seems to me it is open from the start cause it warmed up with the car . As well as both lines .. is this normal ? I was under the impression that it will only flow at thermostat temp..
Thanks for any help fellas
Old Jul 15, 2016 | 05:48 AM
Kenny_Stang's Avatar
Hmm, I'm running the Mishimoto with the 200* thermostatic plate, and it didn't open until it had been driven for a while (which kinda stinks because the car went from being just past the top X on the dipstick to under just under the bottom X). It almost sounds like there is either an issue with the thermostat and it is stuck open. Not sure if there is a way to test it off the engine.
Old Jul 15, 2016 | 07:06 AM
spdracerut's Avatar
All oil thermostats allow a LITTLE flow. This is to prevent thermal shock to the system. For example, the oil in the cooler is 30degC and suddenly the thermostat opens mixing it with 100degC oil. The thermal shock from the big temperature differece can cause damage to various parts. So they all allow a little flow even when 'closed'.
Old Jul 15, 2016 | 10:15 AM
chefs2000's Avatar
Ok good to know thanks !
Old Jul 16, 2016 | 11:04 AM
E4RTH WORM JIM's Avatar
Don't know about the above but this is what mocal say:
Also mine gets warm on both lines. I monitor pan temps and all is good so don't worry.
Old Jul 16, 2016 | 01:07 PM
chefs2000's Avatar
Thanks good info .. I'm goin to the Glen this week so need all the cooling I can get [attachment=96951::]
[attachment=96952::]
Attached Thumbnails Mocal sandwhich plate thermo question-image-4026263157.jpg
chefs2000
Jul 14, 2016 12:35 PM
s2konroids
Aug 26, 2013 04:15 AM
Reapur
Jan 10, 2013 10:07 AM
seansniper
Sep 9, 2012 07:52 AM
david.mt
Jun 25, 2011 12:01 AM
