Modifry ECT fix
Old Aug 13, 2010 | 10:15 AM
Mistman's Avatar
Default Modifry ECT fix
I'm just curious how close the modifry ect fix is to actual water temps. I have an AEM serial guage but haven't updated the tables for a more correct reading but when the AEM says ~195ish the modifry quage goes up to the 9th bar which says it's between 180-205. When the AEM drops below about 196ish the quage will drop to the 8th bar which is under 180, not sure how accurate the modifry really is.
Old Aug 13, 2010 | 10:34 AM
Revenge's Avatar
I would like to know this as well, my Turbo AP1 usally runs 3 bars sometimes 4, however I have seen it go up to 5-6 once on a real hot day. I started to freak a bit and turned on the heat. Not sure how many bars I need before I need to shut her down.
Old Aug 13, 2010 | 11:04 AM
camuman's Avatar
update your aem water temp tables and it will be much closer.
Old Aug 13, 2010 | 11:47 AM
siadam's Avatar
I'm using it, seems spot on from what I can tell.
Old Aug 13, 2010 | 03:19 PM
o'malley_808's Avatar
My modifry went to sh*t about a month after I have it and now it just reads 5 bars (AP1) all the time...Been too lazy to send it in for repair I just read the data stream...Anyone have the update water temp table? Mine always sits around 200-220 on whatever table I have (I know its not overheating cause its always been this amount for over 2 years)
Old Aug 13, 2010 | 03:59 PM
AusS2000's Avatar
The cluster gauge takes a while to read the signal (from the OEM EMS or from Modifry's ECT) so it's not really a good indication (on AP1 at least). The serial guage is much more timely and precise.
Old Aug 13, 2010 | 07:17 PM
A51_AP1's Avatar
When I was running the series 1 and using my AIM MXL dash, the 2 were nearly identical. The OEM dash takes 3-5 secs. longer than the AIM b/c the ECT sensor will go back and forth between a number. The OEM dash doesn't go from 2-3 bars unless it's over the amount set on the Modifry.
bjs2000
Apr 16, 2017 05:33 AM
TixonPB
May 3, 2015 05:25 AM
lotus7racer
Apr 5, 2014 06:56 AM
specialist
Oct 19, 2012 04:38 PM
my01s2k
Sep 15, 2006 12:11 PM
