my build
Old Apr 27, 2012 | 08:07 PM
Akblues2k's Avatar
Default my build
engine
-f20c
-aebs sleeved t sleeved block
-o-ringed
-88mm ross 9.5:1 ceramic coated top and moly coated sideskirts
-pauter rods
-arp head bolts
-arp rod bolts
-port matched head
-lightened,poliched, and balanced crank
-toda valve springs
-ti retainers
-rev extra duty x series valves(1mm larger on exhaust side)
-kaiten valve guides
-skunk 2 stage 2 turbo cams
turbo
-full blown sidewinder twin scroll manifold and dump tubes
-twin wastegates
-borg warner s300 83/75 1.00 ar
-3" intercooler piping
-aem boost solenoid
fuel
-full blown dual pump hanger
-dual 290 pumps
-full blown xxl fuel rail
-full blown fpr
-10an feed 8an return
-id1000cc injectors
engine managment
-aem ems v2
cooling
-mishimoto radiator
intake
-afi intake manifold
-bbk throttle body
im just about done with my build and cannot get the car to fire, it cranks but wont fire. ive checked sensors and checked the timing multiple times cause i know it wont fire if its off at all. i have fuel pressure but its not getting into the engine so i checked spark and im not getting that either? another problem is my fuel pump, if i plug the oem ecu in the pumps come on and when i plug in the aem nothing? any help would but thankful. i live in alaska so theres not to many shops to take it to, i want to get it fired before i take it to the dyno and to get tuned
Old Apr 27, 2012 | 08:28 PM
Forcedbird's Avatar
Nice!!! Good luck!
Old Apr 27, 2012 | 08:37 PM
TonysMI4's Avatar
call aem, the aem ecu sometimes does that. its a glitch in the aem. you will have to send it to aem and have it fixed. google it, thats where i read about it about a year ago. that is 100% it.
Old Apr 28, 2012 | 07:35 AM
indi00's Avatar
Things to check:
When you plug the AEM in, did you have a laptop connected to it and load the calibration map?
Base cal. map loaded? What calibration file are you running?
When ignition is on position, the fuel pump should prime.
Old May 2, 2012 | 12:18 PM
Akblues2k's Avatar
I can't even get the Aem to connect to the laptop? I've tryed multiple cords and it won't connect
Old May 2, 2012 | 02:40 PM
passmans2kny's Avatar
are you sure the usb you are using on the laptop is for transfering data, bc some are only for charging
Old May 2, 2012 | 03:29 PM
Akblues2k's Avatar
I tryed every USB port on the laptop. As far as the cable you think the one provided with the ems would work.
Nikosnoopy
Cars for Sale
Mar 4, 2017 06:24 PM
passmans2kny
Aug 8, 2014 11:58 AM
Rollinx25
Apr 19, 2012 04:30 PM
yutyut
Apr 19, 2012 07:05 AM
tranceporter
Jan 13, 2011 07:56 PM
