need advice on S/C s2000
Old Aug 16, 2007 | 10:08 AM
fflatulip's Avatar
Default need advice on S/C s2000
i ve just bought previous jason's s2000 with a vortech supercharger on it, the supercharger has been on it for about 4 years, and was replaced once recently. other than rear passenger side wheel bearring problem, the car is amazing and deadly fast.
wonding if anyone could give me some advice of what are the things i have to be careful with or might need work on it.
Old Aug 16, 2007 | 10:32 AM
alejo's Avatar
moving to FI
CKit's Avatar
engrish?
Old Aug 16, 2007 | 05:32 PM
bigworm's Avatar
keep a close eye on your oil levels. The vortech kit(or any aftermarket sc) has some oil lines that feed and drain the oil to the charger, which may leak, so you may want to keep a closer eye on your dipstick.
check the belt tension once a week if possible. I removed one of the trays under the car to gain access to the belt at the bottom of the charger. You should be able to just barely rotate it 90 degrees with your two strong fingers.
Many people are running one step colder plugs( I have ngk 7173's), so you may need to change them out. Some guys change them every 3k miles, but I will just do 4k miles or a season.
synthetic oil changed often (3-6 k miles.) vortech recommends syn oil
get a vortech manual from the website if you dont have one and read it, I am sure I am missing a few things.
congrats on the purchase,
hope that helps.
Old Aug 16, 2007 | 09:38 PM
fflatulip's Avatar
thanks a lot bigworm, that definately helps, appreciated
Old Aug 23, 2007 | 10:08 PM
fflatulip's Avatar
will ngk 7173s have any negative effect on my aftermarket sterio, amp and sub???
DaWorm
Mar 22, 2008 09:50 AM
legendman
Jan 11, 2008 03:50 PM
O-turn
Jun 28, 2007 11:36 AM
Anthonymv
Sep 27, 2005 10:27 AM
CarbonFiberLip
Oct 1, 2003 08:29 PM
