Need AEM Infinity map
Hey guys,
I've switched to the Infinity and am in need of a base map or even a fully tuned map (from a good tuner) from someone that doesn't mind helping me out in getting mine up and running. I do have o2, oil and fuel pressure sensors and will be using them with the fail safe mode if that helps and someone has a similar setup with these parameters they don't mind sharing.
Thanks
Thanks
Hey guys,
Thanks
Thanks
Anyway: Does the AEM provided basemap enable your car to start/idle? In general you're much better off just going to a reputable tuner. That tuner could likely provide a modified basemap that takes into consideration your setup.
vietdragontekx
Dec 7, 2010 12:25 AM
