Need AEM 1.19 map
Old Jul 24, 2006 | 01:29 PM
kinetica's Avatar
Default Need AEM 1.19 map
Can someone please send me a AEM EMS 1052 map v 1.19? It would be great if it had a close set up to my car for the tuner to be able to trim and tune. look at my sig for my setup. It does not have to match my setup, could be at least the base map.
Send to ben777@cox.net
Thank you so much in advance.
Old Jul 24, 2006 | 01:45 PM
Scorpion's Avatar
What map sensor?
Old Jul 24, 2006 | 01:58 PM
kinetica's Avatar
OEM map sensor
Old Jul 24, 2006 | 02:11 PM
jbotstein1's Avatar
Did you get a serial gauge? I don't know what version I have, and I am a little worried about that since my gauge is here and just waiting to be installed. What do you need to do to check out the version you have?
Old Jul 24, 2006 | 02:58 PM
ex-eclipse's Avatar
It should say at the top right when you connect and open up aem pro. For example: WORKMAP-S2000.v.1.19 or something like that. You either have v.1.11 or v.1.19. Scorpion knows more about all this crap than any one else on here. Or atleast he helps everyone more.
Old Jul 25, 2006 | 05:19 AM
kinetica's Avatar
The tuner wants to get started this morning, so help ASAP is greatly appreciated.
Old Jul 25, 2006 | 10:21 AM
Scorpion's Avatar
I didn't see this until just now, if you still need the map let me know, I am at work right now so I won't be able to get one to you for another couple of hours. Just let yme know if it's still needed.
Old Jul 25, 2006 | 10:29 AM
kinetica's Avatar
I still need a map.
Thanks.
Old Jul 25, 2006 | 03:26 PM
kinetica's Avatar
Its probably too late today, but I can still use the maps for tomorrow. It will basically cost me double for tuning without a base map to start from.
Old Jul 26, 2006 | 07:35 AM
timg's Avatar
AEM provides a good base map. It will start and run a stock car. Any decent tuner should be able to take it and in less than 5 minutes have a map that will start and run your car even with the larger injectors and SC.
Built in or external UEGO?
PM me with your e-mail. If you still need a map, I can make one and have it to you by lunch today.
Tim
blink962
Oct 10, 2016 08:04 AM
roi
May 20, 2011 06:02 AM
vietdragontekx
Dec 7, 2010 12:25 AM
518135
Nov 18, 2008 01:52 PM
ChefJ
Apr 24, 2007 07:47 PM
