Need: AEM V2 MAP FOR GTX3576R
Old Apr 17, 2016 | 07:48 AM
guy13's Avatar
Default Need: AEM V2 MAP FOR GTX3576R
Hi All
I'm after a map for my boosted s2k. Can anyone help?
I have an inline pro kit with a stock motor. Head has springs and retainers. Running a GTX3576R turbo. Looking to do boost by gear but it would be great if anyone can start me off with a map.
Thanks in advanced.
Old Apr 20, 2016 | 06:53 PM
Jin_SK's Avatar
Do you have a tuner?
Old Apr 21, 2016 | 05:05 AM
guy13's Avatar
I have a tuner and we have used a base map.
Old Apr 21, 2016 | 06:34 AM
JUSTINTHECOASTIE's Avatar
If you have a tuner and a base map, have your tuner get to tuning and set-up everything you need. If you're planning on using someone else's map, you need to list your full-set-up, injector sizes included and what psi you plan on running for power.
Old Apr 21, 2016 | 06:36 AM
guy13's Avatar
Thanks. I'll do a build tread and post my map for others in future.
Old Apr 28, 2016 | 09:17 AM
Prokaw875's Avatar
Your tuner should be able to build you a whole custom map if he is competent. Also when it comes to maps the turbo is not important... You should more be looking for your same MAP sensor, Injectors, and that criteria over the "hard parts" like turbo, valvetrain, etc. Those parts don't really change anything on the map. But if you already have the base map on the car and its running you should be having a custom map/tune for your application now. Not looking for a map that works for your car since every car will be different and honestly we all have to spend money to pay for a custom tune... I know personally I would never hand out my tunes I have paid hundreds and even thousands of dollars for. Good luck with the build.
hondacrazyhonda
Dec 29, 2017 05:55 AM
benje1990
Oct 9, 2011 12:37 PM
Reborn56
Feb 12, 2007 03:22 PM
kinetica
Jul 26, 2006 07:35 AM
