Need base map for comptech 6 psi
Old Aug 19, 2012 | 10:04 AM
LaLan7's Avatar
Default Need base map for comptech 6 psi
Hi, i recently buy an aem ems and i need a base map just to run the car to the dyno i have a comptech with the stock pulley(6 psi) without aftercooler
thx
Old Aug 19, 2012 | 01:48 PM
jordannn93's Avatar
Pm me
Old Aug 19, 2012 | 06:20 PM
LaLan7's Avatar
with stock injector !
thanks
Old Aug 21, 2012 | 05:32 PM
LaLan7's Avatar
bump
Old Aug 21, 2012 | 06:06 PM
s2000Junky's Avatar
Hope your planning on running an Aftercooler or FMIC if you value the longevity of your motor. At 6psi your better off spending the money on that, then a full EMS. Just make sure your running a target of 11.5-12.5afr and retard 1 degree of timing from full OEM timing advance per every psi of boost you make, So it will be retarding 6psi total at redline. That will get you on the road safely. You can fine tune from there at the Dyno. Fyi, the base 6psi comptech kit is stupid reliable given the proper fuel ratio, and it runs oem timing advance. But that's assuming your running some form of IAT cooling and you are not
Old Aug 22, 2012 | 03:16 PM
Reapur's Avatar
You can drive the car with the supercharger setup totally installed minus the drive belt for the blower installed.
This means you can drive the car like stock to the tuner then install the EMS and belt once you get there.
Old Aug 22, 2012 | 04:12 PM
camuman's Avatar
X2
Old Aug 22, 2012 | 07:54 PM
s2000Junky's Avatar
X2
x3 One of the perks of a Supercharger
Old Aug 22, 2012 | 07:59 PM
LaLan7's Avatar
ok thx
TheBigShow
Aug 16, 2009 09:22 PM
VegaS2k
Sep 3, 2006 07:00 PM
Riceboi
Aug 10, 2006 11:38 AM
Titounais
Apr 30, 2006 01:31 AM
my01s2k
May 26, 2005 08:58 AM
