need help
Old Oct 1, 2005 | 08:58 AM
ak__s2k's Avatar
Default need help
i just installed my bov godzilla . and i rev it up and it does not want to blow off. has any body had this problem? maybe i connected something wrong?
Old Oct 1, 2005 | 10:09 AM
VeilsideAP1's Avatar
did you adjust the spring? There should be an alan key screw on the top of the BOV that you can adjust from hard to soft...
Old Oct 1, 2005 | 12:26 PM
revhi's Avatar
Is the vacuum line in the right place on the BOV? Should be on the top hole.
Old Oct 1, 2005 | 01:40 PM
ak__s2k's Avatar
thanks it was the vacum line it wasnt in now it works
Old Oct 3, 2005 | 09:58 PM
C4SxM5's Avatar
i am having the same problem, but my vacum lines is attached
VeilsideAP1:by turning the alan key screw, would it effect anything else other than the sound of the BOV? just not sure what it actually does.
thanks for any help!
Old Oct 3, 2005 | 10:07 PM
SIIK2NR's Avatar
Turning the Allen key is going to make the action of the BOV spring harder or softer. If you are running a SC setup and you cannot hear it venting...then your spring is too stiff and you need to loosen it. Keep testing it till you can here it vent and you will be able to hear it discharge at higher boost levels.
If your BOV is right in the middle of being too stiff and just right...you will get the "gobbling turkey" sound instead of a nice discharge.
Tim
Old Oct 3, 2005 | 10:10 PM
C4SxM5's Avatar
thanks, I'm going to try it tommorrow
freq
Oct 8, 2016 03:17 AM
estooki
Feb 17, 2012 08:54 PM
wheelspk
Nov 3, 2010 04:39 PM
Jersey
Sep 1, 2008 12:53 PM
kkilbane
Nov 5, 2006 01:21 AM
