Need help installing turbo coolant lines..
Old Jan 7, 2008 | 05:15 AM
MuckaLun's Avatar
Default Need help installing turbo coolant lines..
I'm in the process of installing my turbo and need help with installing the turbo coolant lines.
1. Does anyone know if the turbo inlet/outlet for coolant works both ways? it looks like its the same and inlet/outlet on turbo can be swapped...if not, how can i tell which is in and which is out?
2. Since i'm running an oil relocation kit, i've looped/rerouted the factory oil cooler lines with an 8" hose. I'm thinking about running the in and out lines using the outlet near the bleeder and the throttlebody since i can use the same diameter hoses. is this ok and would it provide enough coolant for the turbo without causing the coolant to heat up the manifold?
thanks for helping.
Old Jan 7, 2008 | 08:45 AM
PatS4P's Avatar
Banned
1) No in or out on turbo cartridge, either way
2) I was advised to use the oiler cooler line out of block to feed the
turbo and use the other oil cooler line for the return.
Old Jan 7, 2008 | 11:25 AM
MuckaLun's Avatar
[QUOTE=PatS4P,Jan 7 2008, 09:45 AM] 1) No in or out on turbo cartridge, either way
Old Jan 7, 2008 | 11:44 AM
PatS4P's Avatar
Banned
Bump
Old Jan 7, 2008 | 02:58 PM
AusS2000's Avatar
I did the same. Removed the stock oil cooler and used the lines with reducers to cool the turbo. Works great.
Old Jan 8, 2008 | 03:53 AM
indebt&lovinit's Avatar
I am about to fix my lines, also from the oil cooler.
The rubber lines kept blowing off wile I was tooling down the road.
I am going to be going from the turbo to the radiator instead of reusing the line that goes across the front of the engine back to the water pump. I will just plug the line off at the pump and remove the hard line.
sense I do not know how to weld and don't know any one that dose I thought about unthreading the bung on the side of the block cut off the nipple and tape it and the radiator with a 1/4 NPT and use 1/4 NPT to 6 AN fittings
the turbo needs two 14 MM 1.5 pitch to 6 AN fittings and then all I need are two 6 AN 90 degree and two strait 6 AN fittings and about 6 feet of the braided line and that will hopefully fix the problem for good.
Ek_Jak
May 19, 2010 04:18 PM
Kado413
Dec 7, 2009 09:12 AM
s2k54
Dec 1, 2008 08:32 PM
AusS2000
Aug 2, 2007 09:57 PM
Kwando
Jul 2, 2005 10:03 PM
