Oil restrictor for precision turbo
Originally Posted by Deception,May 19 2010, 02:33 AM
ball bearing or journal?
Details are your friend, help us help you.
Originally Posted by Ek_Jak,May 19 2010, 01:40 PM
its a journal bearing precision 5857s .63 ar
All the problems I had with smoking stopped when I tapped the oil return to the girdle, I would recommend the same.
You dont need a restrictor with the JB Precision turbo's, just make sure youre using a -3 feed line and at least a -8 return line going to the girdle. Also, it may be best to take the oil feed from the filter relocation block on the engine block, but if youre not using a filter relocation block, you can go from the factory pressure sensor area.
