need help (pics of oil pan tap)
Old Nov 9, 2005 | 06:30 PM
bullet1123's Avatar
Default need help (pics of oil pan tap)
there was recently a picture in an FI thread of a modified oilpan, with both baffles welded in and the oilpan tap welded in place. I tried the search engine and had no luck. If anyone couls post these pics or a link to them i would really appreciate it, I want to show my welder what i had in mind!!!!!!!!!
Thanx
Old Nov 9, 2005 | 06:49 PM
Sideways's Avatar
https://www.s2ki.com/forums/index.php?showtopic=332447
Also check out Alaniz:
Old Nov 9, 2005 | 09:34 PM
bullet1123's Avatar
thanx sideways..that will deffinetly help, but the picture im talking about showed the fitting actually welded to the pan from both sides........
Old Nov 10, 2005 | 03:23 AM
MB's Avatar
MB
Member
https://www.s2ki.com/forums/index.ph...=325803&st=100
Have a look half way down.
Make sure your welder uses the right procedure for welding an aluminium. I chose not to in the end in case it distorted the ally. Not too likely but I just used loctite on the threads.
MB
thebugsarebad
Mar 12, 2014 03:54 AM
riceball777
Jun 9, 2010 11:43 AM
s2sik
Jul 30, 2009 09:54 PM
s20004lifehomes
Jun 2, 2009 02:19 PM
Costas
Aug 10, 2004 10:28 PM
