need help on turbo s2000 ?
Old Jul 8, 2008 | 02:56 PM
s2000Turkey's Avatar
Default need help on turbo s2000 ?
i have custom turbo kit with pfab log manifold with 38mm tial wg
everthing seems ok but the car boost 0.4 bar until 7000rpm after 7000rpm it boost 1.0 bar and stays there .
By the way my tial spring is 1.0bar and i am using Fcon Pro
need everyones help
Old Jul 8, 2008 | 03:03 PM
9KRDLIN's Avatar
boost leak... or you have a huge leak in the exhaust side before the turbo... what size turbo???
Old Jul 8, 2008 | 03:04 PM
UberDuper's Avatar
1 bar == 14.5psi dude.
Doh. Didn't read that last bit about your spring.
UD.
Old Jul 8, 2008 | 03:12 PM
we have checked the car there is no leak anywhere my turbo is gt30r(BB)
Old Jul 8, 2008 | 03:13 PM
UD.
umm dont understand what u mean
Old Jul 8, 2008 | 03:20 PM
UberDuper's Avatar
Without reading that you had a 1bar spring I'd assumed you were trying to get less then 14psi.
UD.
Old Jul 8, 2008 | 03:24 PM
UD.
no i am trying to make it 1.0bar always but it doesn't get over 0.4bar until 7000rpm
Old Jul 8, 2008 | 05:51 PM
timg's Avatar
In what gear? That's somewhat reasonable in first gear. If it does that in third or fourth gear, you have a big leak or a other problem.
Tim
Old Jul 9, 2008 | 03:32 AM
it does in every gear
Old Jul 9, 2008 | 03:49 AM
Raven628's Avatar
Check your couplers. The one coming off your compressor housing may be loose, or have a hole in it from heat.
