Need input for which oil cooler
Old Sep 8, 2008 | 09:08 AM
bruthaboost's Avatar
Default Need input for which oil cooler
Hello all,
I'm at an impasse. I'm putting on a twin scroll top mount and it's requiring me to remove the stock oil cooler. I have no problem with this. Seeing as real estate is tight I'm going to be using an air unit and fitting it inside an aluminum radiator (I'm just going to cut out the rows I have to (about 6"-8" depending on the cooler size) and weld it in. The core size is double the stock one, so losing 6-8" shouldn't cause any problems.
My question is which cooler will be best/adequate.
I'm down to two choices. The earls will be easier to fit and all I lose is about 7" of radiator. I'll be wedging it on the condenser fan side. The fluidyne will require quite a bit more rewelding and I'll lose about the same amount of rows.
Here are the two:
fluidyn
http://store.summitracing.com/partdetail.a...15&autoview=sku
and earls
Old Sep 8, 2008 | 09:59 AM
GDM S2K's Avatar
I dont run a cooler due to pressure drop,
Old Sep 8, 2008 | 10:17 AM
devs2k's Avatar
who made the manifold? do you have one or two external wastegates?
Old Sep 8, 2008 | 10:37 AM
It's a one-off from Pang that was originally setup for a t4. It used to be setup for two wastegates. I had it merged to one. He's still working on the downpipe.
AFs2k
Nov 23, 2010 05:23 PM
nail13
Feb 19, 2010 06:29 PM
Ramocheese
Jan 18, 2010 05:24 PM
radtech
Oct 16, 2006 08:47 PM
