Need to make metal gasket....
Old Jan 1, 2008 | 11:46 AM
05TurboS2k's Avatar
Default Need to make metal gasket....
Need to create 2 gaskets.
Turbo - Downpipe
Exhaust manifold - Turbo
The originals were just thin sheet metal. Best way to do this, I tried running without them...both leak lightly without a gasket in place.
Any reason I shouldn't go to kragen (assuming they sell it) and make one out of sheet metal gasket stuff???
Old Jan 1, 2008 | 12:11 PM
ChefJ's Avatar
Have all of the edges machined flat. Nothing is tighter then 2 pieces of perfectly flat metal. This is why inlinepro doesn't use gaskets. I have friends that try and use high temp gaskets and they still burn up and leak eventually.
Old Jan 1, 2008 | 12:16 PM
05TurboS2k's Avatar
I used em prior...but tossed em thinking it'd be better to have no gasket for exacctly that reason.....was a mistake. The pieces WERE flat but eventually the heat seems to warp the down pipe flange and now it doesn't work out.
Old Jan 1, 2008 | 12:20 PM
05TurboS2k's Avatar
the turbo and the exhaust manifold are both machined as is....
recently I ceramic coated the hot side of turbo....perhaps they'd seal up now? ...very iffy.
The flange on the DP obviously is just a flange maybe I could sand it flat with a T bar and sand paper over it...... try it again. It didn't leak hard just a little.
Old Jan 2, 2008 | 03:36 PM
SoCalIsMyLife's Avatar
the only thin metal sheets available locally I can think of is aluminum flashing. don't think they sell thin sheets of stainless anywhere locally. If you want steel just go to a junkyard and cut off a piece of the side of a van
It might be easier to just order the gasket you need. ATPTURBO.COM is a good supplier
nissfam
Sep 15, 2012 08:40 AM
Lilbastrd
Jun 18, 2012 04:42 PM
SPECIAL-OPS-S2K
Sep 1, 2008 10:33 AM
S2Krazee
Aug 25, 2008 12:01 AM
Soul Coughing
Aug 30, 2007 05:19 PM
