Need some help, completely lost
Originally Posted by sawgei,Jul 15 2008, 07:58 AM
so would i need to change the pulley and then have the dyno shop retune the car? btw where can i buy an undersized pulley for the supercharger?
Originally Posted by sawgei,Jul 14 2008, 09:27 PM
The car make inconsistent 1-2 psi of boost under it hits 6k. Also between 4k-6k its flat. Does anybody have any idea what it could be?
Thanks for all you guys help. I put on the new belt and check for any leaks today. the new belt works a lot better and there no leak. The car feels a lot smoother but still hesistate at 4k when i full throttle it. Runs fine if i only 3/4 throttle. I finally tested the tps sensor and found a dead spot in the tps sensor. I will try to find a tps sensor and install tomorrow and see if that will fix the problem. I will keep you guy posted. Hopefully thats all the problem. thanks again.
The size of the throttle body has no effect on the injectors. You can buy a 72mm but it will be no different to stock.
If I were you I'd stop fiddling with it and adding more variables and get it running properly.
hvAlfaWant_S2000
Mar 30, 2015 10:07 AM
