new clutch w\ sc
i have a comptech sc w\ ac and my clutch is slipping bad. just wondering for guys w\ aftermarket cluches which one you like the best and also which ones are closest to stock feeling on the clutch pedal.
Just a heads up to get that swapped out ASAP and try to drive it as little as possible.
the stage 2 or stage 3 would fit the bill the best:
http://automotivespeed.com/index.php?cPath=23_28_38
You guys are saying the Exedy stage I wont hold even with the lowest boost? The clutch you want depends on how you drive. If you want to beat on it, a puck would be better for power handling. In turn, this will make it less daily drivable and puck clutches are made for racing, so the rate at which they wear did not really matter that much to the company making them if you get my drift.
See if you can still get a disc rather than puck that might still hold.
Glock19carrier
Aug 14, 2012 03:57 PM
