New fuel setup for 700hp and E85
Old Feb 12, 2012 | 09:14 PM
1SlowSi's Avatar
Default New fuel setup for 700hp and E85
I'm looking into a new fuel setup to support 700whp+ on e85 and would like to know what the best/cost effective way would be. I have an inline Bosch and intank walbro and don't want to buy the full blown setup (unless I have to). My first question is... Does the Bosch flow the same or higher volume at lower base fuel pressures? I would like to just buy one more Bosch and run them together off of a surge/sump tank.
My next question is...what if I ran my walbro in tank with Bosch inline to some ID2000 instead of my current ID1000s? What power could I do with that? Right now I am running the inline Bosch/intank walbro setup 100 psi base and maxed out at 600hp. If I ran dual external boschs to a surge tank, could 1 walbro feed the tank fast enough? And last question...if i ran 2 external boschs from a sump setup, what injectors/base pressure would ii need? Sorry for so many variation questions but there are so many ways to supply fuel!! Any recommendations would be appreciated! Thanks guys.
Old Feb 12, 2012 | 10:38 PM
DFWs2k's Avatar
I'll insert the t1/id injector and fuel pump chart when I can. Get id2000s.
Sent using free Tapatalk - Android FTW
Old Feb 13, 2012 | 05:34 AM
1SlowSi's Avatar
Thanks. I guess the main concern is if I do a surge tank, will the walbro be able to feed it fast enough for the dual boschs coming off of it.
Old Feb 13, 2012 | 06:10 AM
InductionPerformance's Avatar
The surge tank with two Bosch 044's is going to be your best bet. With the ID2000's you would want to run your base pressure at or around 43lbs. I've made over 800whp with this setup.
Old Feb 13, 2012 | 08:09 AM
1SlowSi's Avatar
This makes me smile Now I just have to find funds for the ID2000's and another bosch lol. Thankfully, the surge tank build will be free of charge minus the fittings.
Old Feb 13, 2012 | 08:22 AM
Killer_B's Avatar
Good info!
Old Feb 13, 2012 | 11:28 AM
B5254T4's Avatar
I will run dual FBM 340´s inside a surge tank, will make a Y in the top going to a AN10. Can´t go wrong.
Old Feb 13, 2012 | 08:53 PM
1SlowSi's Avatar
Surge tank will be made soon
Old Feb 13, 2012 | 09:17 PM
DFWs2k's Avatar
Old Feb 14, 2012 | 04:09 AM
spectacle's Avatar
Where are you putting it?
