New fuel setup for 700hp and E85
Old Feb 14, 2012 | 06:12 AM
1SlowSi's Avatar
Originally Posted by spectacle
Originally Posted by 1SlowSi' timestamp='1329198830' post='21412440
Surge tank will be made soon
Where are you putting it?
Most likely where the spare tire is at. You know what else is great? I just woke up to my garage being soaked from a water line break out and of course there is an inch of sitting water in the car and 5 gallon in the trunk! Way to start the day
Old Feb 14, 2012 | 06:53 AM
sohc_mshue's Avatar
Originally Posted by spectacle' timestamp='1329224963' post='21412973
[quote name='1SlowSi' timestamp='1329198830' post='21412440']
[/quote]
ewww thats no good
Old Feb 14, 2012 | 06:58 AM
1SlowSi's Avatar
Originally Posted by sohc_mshue
Originally Posted by 1SlowSi' timestamp='1329232379' post='21413281
[quote name='spectacle' timestamp='1329224963' post='21412973']
[/quote]
ewww thats no good
[/quote]
I took pictures made sure my ecu, fuel pump relays and wiring weren't affected and so far so good. Now it's time to get this car out to a shop and have taken apart/cleaned.
Old Feb 14, 2012 | 07:02 AM
Irishflame27's Avatar
Here is my old setup, worked like a champ!
here is a breakdown
15ft of -8 SS hose
15ft of -6 SS hose
Bosch 044 with -8 fittings and CNC bracket
Fuelab 5350-1 "EFI" Regulator (2) -6 In (1) -6 Out...with fittings
fuel pressure gauge
fuel filter with your choice of element and CNC bracket and -8 fittings
4 -6 straight hose ends
1 -8 to -8 female coupler
2 -8 90's
2 -6 90's
3 -8 straight hose ends
1 -8 inlet fitting for InlinePro or Full blown fuel rail
1 -6 outlet fitting for inlinePro or full blown fuel rail
6.5x6.5x6.5 (volume =274.625ci or 1.18gal) fuel surge tank
Old Feb 14, 2012 | 07:30 AM
1SlowSi's Avatar
I've had that picture saved for quite some time now haha mine will be very similar except with dual boschs. I have a question about the chart above. At 100psi base and id1000, is a single Bosch working past it's normal operating pressure range? If I'm going to be adding a second one I want to make sure that mine is still good as new because I've been running it like that for a year and a half.
Old Feb 14, 2012 | 12:19 PM
mase1's Avatar
why not the dual intake pump setup like the Full Blown Hanger?
Old Feb 14, 2012 | 12:27 PM
passmans2kny's Avatar
^i agree, dual 340s and your good for 1000 hp
Old Feb 14, 2012 | 05:42 PM
efi2nr's Avatar
Dual FB340s on a FB -10 hanger with id2000s here. Made 757hp on e85 at about 75% duty
Old Feb 14, 2012 | 06:14 PM
1SlowSi's Avatar
I think I chose this because another Bosch is $190 and surge tank is free. The hanger is $400 so I'm basically saving $200. Is the hanger really worth $200 over having a surge tank setup?
Old Feb 14, 2012 | 06:52 PM
ScorpioMk's Avatar
A plus to the hanger setup is you have less chance for leaks, and dont have a fuel cell inside the car.
