New fuel setup for 700hp and E85
Old Feb 15, 2012 | 05:51 AM
  #21
InductionPerformance's Avatar
Originally Posted by 1SlowSi
Originally Posted by efi2nr' timestamp='1329273741' post='21415453
Dual FB340s on a FB -10 hanger with id2000s here. Made 757hp on e85 at about 75% duty
I think I chose this because another Bosch is $190 and surge tank is free. The hanger is $400 so I'm basically saving $200. Is the hanger really worth $200 over having a surge tank setup?
Another good thing about the surge tank is not having to ever worry about fuel slosh.
Old Feb 15, 2012 | 09:31 AM
  #22
dsddcd's Avatar
If you are going to run a surge tank I would HIGHLY recomend the Integrated Engineering submerged tank in either single or dual.
http://www.intengineering.com/integr...-044-pump.html
Old Feb 15, 2012 | 03:29 PM
  #23
1SlowSi's Avatar
Ill pass on that man but thanks for the recommendation.
Old Feb 18, 2012 | 08:14 AM
  #24
1SlowSi's Avatar
Im thinking about taking out the Walbro 255 and putting in the stock fuel pump to feed the surge tank. Is the stock intank enough to keep the surge tank full with dual bosch's coming off of it?
Old Feb 18, 2012 | 08:40 AM
  #25
sohc_mshue's Avatar
Why you want to do that?
Old Feb 18, 2012 | 08:43 AM
  #26
BatmanCR's Avatar
I bit the bullet and got the hanger.. Really straight forward and convenient with the capabilities of 800+whp. Cant ask for more.
Old Feb 18, 2012 | 09:19 AM
  #27
1SlowSi's Avatar
I don't necessarily want it, I just wanted to know because since I'll be working on the fuel pump stuff, I wanted to put the reliability factor back in place. I am going to leave the walbro in there since it works.
Old Jul 27, 2014 | 07:42 PM
  #28
WootRWD's Avatar
Did you end up going this route op?
Old Jul 31, 2014 | 11:06 AM
  #29
Prokaw875's Avatar
My same setup man. Walbro 255 intank -8 feeding the surge tank. Dual -10 ports. Dual 044's, Y fitting to -10 feed to a full blown xxl fuel rail, ID2000, -8 return through a weldon regulator, -8 return to the surge tank, and a -8 overflow from surge tank to the stock tank. Figure I'll be good with this to 1000hp on fuel or 800hp on Ethanol easy. Also going to add a flex fuel sensor and zeitronics ethanol concentration gauge.
Reason I am going this system is I want something that can handle big power with ethanol or gasoline. The "end all be all" setup hopefully! Lol
Old Jul 31, 2014 | 11:40 AM
  #30
bottleboy's Avatar
im trying out the science of speed system a walbro 450 in thank and dual 320 in surge tank im hopping this will supply the needs of the beast
its been stuck at the border since monday hope they figure out soon what it is and let it true duties lol
before it snows
