New supercharger kit
Originally Posted by trivium,Nov 2 2006, 10:05 PM
So why exactly isnt a twin screw available for the S yet?
Originally Posted by 73Zero,Oct 31 2006, 11:52 AM
It's interesting how he's utilizing Rotrex supercharger units in his kits now, rather than the Roots blowers he was using before.
If you want your car to have extra power only at the top of the RPM range - you can go with a Rotrex (centrifugal "junk" like the Vortech and the like). Your car won't be fast but you will still have a good peak horsepower number to brag with (and most people who have no idea about performance will pay attention to just that peak hp number)
But if you want your car to be absolute beast - you better get kit with a positive displacement supercharger - either the Eaton units or a twinscrew one (Opcon/Whipple or Autotor). It will eat alive one with similar peak hp and centrifugal blower.
Originally Posted by slimjim8201,Nov 2 2006, 12:27 PM
Not a bad summary, but I believe it is the roots-style charger that specifically does not have contacting lobes. Most twin-screw (Whipple) chargers have a ceramic coating on the lobes that initially causes them to "interfere" so that a perfect seal can be achieved. This seal is much less important with the roots design due to the lack of internal compression.
The Roots heat generation is largely due to inefficiencies in the design, in that it causes the air to "crash" together upon exiting the lobes.
I'll post come CFD images shortly. Pretty sexy stuff...
From your site:
The twin screw also differs from the roots in that the rotors do not ever actually touch which reduces wear and friction (heat) greatly.
From your site:
The Eatons which people call roots are actually twin-screw/roots hybrids.
And at less than 20 psi of boost you'll get similar results no matter using an Eaton or a twin screw Opcon/Whipple/Autorotor. Either one of these will work great under the hood of your car
Originally Posted by mx5,Nov 3 2006, 12:03 AM
Nobody makes roots blowers nowadays.
You will not get similar results between an Eaton/Magnussen and Whipple/Autorotor at almost any boost level. The latter will consistently out-performn the former due to the same big word I've been throwing around: internal compression. This really is the limiting factor of the Eaton/Magnussen unit or any Roots style blower for that matter. The only downside to this is that you are ALWAYS compressing air when the blower is spinning, whether you use it or vent it to atmosphere. Less efficient when off boost, more efficient when on.
Turbos/Centrifugals/Twin Screws each fall into both the compressor and air pump category, some more than others. The Roots style unit is ONLY an air pump. It does not have the ability to compress the charge on it's own.
The Rotrex unit is interesting. It uses a planetary traction drive vs. gears or belts. The drive allows MUCH higher RPM vs. a typical centrifugal blower, so the Rotrex can use turbo impellers. These are more efficient due to higher RPM, smaller diameter for the same boost (less rotary inertia). Of course there is still parasitic load to spin it, but the dyno plots show the unit to be less peaky than a normal centri. HKS and www.w2wpowertrain.com have dyno plots of various motors.
-Doug
-Doug
This thing could be a pretty pimp low boost plug and play solution...
Good low end torque, good high rpm power
at 5-7 psi just a basis plug and play ems
no headgasket
no oil tapping, engine oil is still a sealed system
at those boost levels would it even need an after/intercooler?
if this put around 300whp down with a good power curve and a price take around 5k I 'd rock this....
Matt
no headgasket
Matt
One of the cheapest examples - the Miata world. Lots of experience there and almoste any form of forced induction has been tried and compared vs the others in real life. There are kits using: the Eaton blowers (MP62 from BRP/SOT); the Swedish Opcon (sold in USA by Whipple) by Flyin' Miata in the past and now BEGI; Autorotor in the Kenne Bell kits.
People use these in their Miatas and at similar boost/flow levels get similar hp results. The twin-screws' avertisements sound like these blowers are much more advanced but the Eatons are no slouches either. There is no day and night difference. Even if a twin screw makes a couple more hp than an Eaton it is not the end of the world - the quality of the whole kit is much more important.
Btw, still the highest sc Miata hp crown is held by an Eaton equipped Miata - RJW had a homemade Eaton MP62 kit, running 20+ psi, W/I intercooler plus water injection and boosting the stock 100 rwhp Miata output to over 340 rwhp. Here is his 7000 rpm dyno run, later he was running his built engine to 8700 rpm redline
The centrifugal blowers also have been used in the Miata world by some manifacturers but with these folks got peak hp numbers at high rpm and weak power below that ... so noone was buying these
Originally Posted by Ubetit,Nov 3 2006, 08:14 AM
