New Turbo Oil Cooler
Originally Posted by kane.s2k,Aug 10 2006, 07:53 AM
http://automotivespeed.com/product_info.ph...&products_id=50
There is a pic of it on there. As you can see it has a longer piece.
Problem is that the inlinepro has a pressed in fitting where the oil filter attaches.
I just got off the Phone with John over at Inline he suggested that I go with and Oil cooler kit that he sells. Basically instead of being a liquid to liquid such as the Factory cooler it would be a air to liquid "basically a small radiator"
How it would work is the line that comes off the bottom of the fitting on the block would attach to one end of the cooler and the other end of the cooler would be ran up to the filter. So what you are basically doing is putting a air to liquid cooler "INLINE" of one of the current lines that runs to the filter. I'm going to order it and I will take pics once its here
Originally Posted by PRS2K,Aug 10 2006, 01:01 PM
That longer piece is a factory piece. If you look at the pictures I posted above you will see a small end sticking out of the front of the cooler the rest of it is ran through the cooler. The longer piece shown in that kit is factory and is already on the car it is used to hold the oil cooler to the block and the small end that sticks out
Yep thats what it is...I don't have an oil temp gauge, but I did notice that my coolant temp was roughly 5 degrees cooler after I got the oil cooler installed...
I'll post pics too if I can find my camera, lol
