oil restrictor for inline pro kit
Old Oct 6, 2010 | 09:56 PM
ZSAK's Avatar
Default oil restrictor for inline pro kit
Hey guys I was wondering if I ordered the right restrictor for my kit?
oil restrictor
Also for installation is it as easy as taking the oil supply hose off near the turbo take old fitting off and put this fitting on? Sorry for the simple question just want to make sure.
Old Oct 6, 2010 | 10:12 PM
Competitor9's Avatar
I'm guessing this is the inlet at the top of the turbo? your running inline pro. I thought it was a -5 but I am not sure, give them a call tomorrow tom is more then helpful.
Old Oct 7, 2010 | 05:35 AM
1SlowSi's Avatar
Doesnt look like the one that came with my kit. That looks aluminum? But yes, just screw that into the turbo, reconnect the oil feed line and you're set.
Old Oct 7, 2010 | 07:42 AM
TRBOKEV's Avatar
Are you running a ball bearing 5965?
That's the correct size for ball bearing watercooled.
I'm running a .035 restrictor with -4 feed and have had zero issues.
Old Oct 7, 2010 | 09:06 AM
ZSAK's Avatar
ya its a bb turbo. just wasn't sure on size. I have the same one as you kev. Should I have them send me a -4 feed instead of the -3an?
Old Oct 7, 2010 | 09:08 AM
TRBOKEV's Avatar
No the -3 will be just fine.
Old Oct 7, 2010 | 09:22 AM
D1sclaimer's Avatar
I didn't get a restrictor with my InlinePRO kit either. You would think that'd be a necessity for a turbo kit.
Old Oct 7, 2010 | 09:52 AM
ZSAK's Avatar
I am trying to troubleshoot my problems first is why I ordered one. My exhaust has been smoking for a bit so I figured I would give this a shot. I suspect the seals are going out on the turbo though. Anyone know best method to check that?
Old Oct 7, 2010 | 11:44 AM
1SlowSi's Avatar
If it's smoking its typically too late but some have been lucky in stopping the smoke. If u need to get it serviced be careful what u tell Precision/Garret when they ask about restrictor and sealant. Although JB don't need restrictors, our cars need it but Precision will void based off that theory. BB on the other hand need them regardless.
skool u
Jun 4, 2009 09:34 AM
josserman
Jun 1, 2009 07:33 AM
NYS2000TURBO
Apr 18, 2009 08:38 PM
otbs2k
Aug 31, 2008 08:56 PM
PRS2K
Aug 10, 2006 11:52 AM
