new turbo and oil, psi question
Old Jun 14, 2014 | 02:06 PM
lude92_si's Avatar
Default new turbo and oil, psi question
Just installed a Borg 200sx fmw and went from 10-30 to rotella 5-40. With my SC setup my idle oil pressure was 18ish... now with the turbo and 5-40 its at 31psi. This ok? Just bleeding coolant and have not driven the car.
Old Jun 14, 2014 | 04:34 PM
starrman's Avatar
Did you change anything with the sending unit? Could be that the SC had worn seals and was causing some pressure loss. There is a thread on here about oil pressure, cold start will be way higher than idle after engine warms up to operating temps.
Old Jun 14, 2014 | 05:11 PM
lude92_si's Avatar
Cold start is in the 80s idle warm is 28-30psi
Old Jun 14, 2014 | 07:37 PM
s2k manic's Avatar
I wonder if my plx gauge is right as my oil pressure is 4-9 psi with oil temps around 230f below 200f 15-18 psi cruising at 3000rpm 55-60psi at 220-230f and 65-70psi below 200f I hope this is ok. I have heard the plx reads low
Old Jun 14, 2014 | 07:43 PM
baZurk's Avatar
80-90+ at start up and 30-35psi at warm idle is normal. My friends stock s2000 sometimes reads 99psi (maxed) when he starts it when cold.
Old Jun 14, 2014 | 09:06 PM
c130turboprop's Avatar
sounds like good pressure to me. thats where it should be without driving. after u drive and get her all hot, your oil psi will be between 10-20 psi at idle.
Glad you got her up and running!!!
Old Jun 15, 2014 | 04:52 PM
lude92_si's Avatar
Its getting there. Not driving it yet just making sure there's no leaks.
Old Jun 15, 2014 | 05:23 PM
henrryxd's Avatar
Seems like ur able to get a estimate on the temp from just reading the oil pressure. Is this true? What would the oil pressure be if the car is 240+ degrees ?
Charper732
Dec 29, 2017 03:48 PM
ninetysixyenko
Nov 16, 2016 10:20 PM
s2k manic
Dec 13, 2012 01:47 PM
Moddiction
Jul 8, 2010 02:24 PM
Moddiction
Jul 7, 2010 11:27 AM
