new wastegate issues
Old May 21, 2007 | 01:48 PM
Tyraid2K's Avatar
Thumbs up new wastegate issues
My mechanic installed a new tial wastegate since my original broke. I was running around with a wastgate and a 4psi spring in it for the time being and the car didn't feel terribly quick.
We swapped for the 7psi wastgate today and I left the shop. It positively RIPPED and needless to say I was in love with it. But just a mile down the road it loses the boost it was holding and I hear plenty of rattling going on under the hood. I popped the hood and it was plain to see the wastegate was loose. I made a call and u-turned back to the shop. Upon further inspection, I had sheared off the head of a bolt holding the wastgate to the flange somehow. These were the bolts that came with the kit from Tial. We threw on some new bolts and I left. But now the car is back to it's ok fast self. It doesn't feel like it did before that original bolt let loose. I pulled over and looked for issues. No exhaust leaks that I could see.
When I got home I had my brother help me check to see if exhaust was coming out of the dump tube hoping to find out if the wastegate was stuck open. I put my hand under the car where the tube should extend to but couldn't feel anything. The car sounds like its letting out a little exhaust from the turbo/manifold area but I can't smell any. It definitely sounds different than it did when I had the bolt that came with the kit on it.
I am at a loss on this one. My car goes for clutch install in a couple days and I've told my mechanic to check it out then. No obvious signs though so I am stumped.
Old May 21, 2007 | 03:10 PM
Tyraid2K's Avatar
I've looked further and I think exhaust is coming from somewhere around the wastgate flange, possible leak but we'll find out I guess.
Turbo S2000 is a PITA
Old May 21, 2007 | 03:15 PM
OGPackin's Avatar
Could it be the wastegate bolts backing out? I had a problem with mine backing out till we used headstuds.
Old May 21, 2007 | 04:10 PM
Tyraid2K's Avatar
ya it very well could be!
I'll check ogpackin because thats where I think the leak is, thanks for the hint
Old May 21, 2007 | 04:27 PM
OGPackin's Avatar
No worries bro!
Old May 21, 2007 | 04:32 PM
Tyraid2K's Avatar
you win OG!!! I put my hand next to the wastgate after starting it up and sure enough I could feel exhaust puffing out of there.
What kind of head studs did you use?
check this out:
Old May 21, 2007 | 04:40 PM
OGPackin's Avatar
check this out:
Yup that'll do it. Glad it wasnt something more expensive..
We used ARP head studs.
Old May 21, 2007 | 07:04 PM
gomarlins3's Avatar
Matt, you are having the worst luck with that install. Hopefully they will get it fixed soon.
martin j
Jul 10, 2016 11:15 PM
S2k007
Apr 6, 2012 12:51 PM
Tyraid2K
May 30, 2007 02:44 PM
S2K:-)
Apr 6, 2006 12:34 PM
amongmany
Feb 8, 2003 03:54 PM
