nitrous questions
Old Sep 24, 2007 | 09:29 PM
MugenS2k615's Avatar
Default nitrous questions
alright i have a stock 01' with jus a cheap intake and an invidiaTP (not installed) and plannin on spraying. maybe getting a zex direct port or zex wet kit. got a fuel safety switch and bottle that alreadi has a pressure gauge on it. goin to use a moment. switch...what i need to know is am i going to need bigger injectors for either kit? a tune? ecu? or what? also plannin to spray about 45-60shot or maybe 75 max (my daily driver, spraying on wkends onli, i hope ) please any info would help...
Thanx in advance
Old Sep 25, 2007 | 04:22 AM
deathsled's Avatar
you shouldnt need injectors or a tune if you're using a wet shot or direct port, as both of those supply nitrous AND fuel and are jetted appropriately (although it is possible to do a direct port shot without fuel I guess). You may need to upgrade your fuel pump just to be safe to make sure you can keep up with the additional fuel demands.
Old Sep 25, 2007 | 09:06 PM
alright thanks for the info deathsled!
Old Sep 25, 2007 | 09:55 PM
oh man i 4got to add, would the stock internals hold up for a while? i heard if i run a big shot the rear end may not be able to hold up, is this true?
Old Sep 26, 2007 | 03:51 AM
BondoBuilder's Avatar
The f20 is probably one of the best motors you could spray with...forged Aluminum pistions, forged steel connecting rods, and 11:1 compression ratio. Do you want nitrous for drag racing?
Old Sep 26, 2007 | 09:06 AM
SC-SUZUKA's Avatar
With a 75 shot of wet or direct there is no need for tunning. I believe if you shot more than 75 than you may need some type of computer tunning.
Old Sep 26, 2007 | 10:28 AM
not so much drag racing (but im sure i will sooner or later to get my time) but mainly highway runs...
Old Sep 26, 2007 | 12:30 PM
S2oooNvegas's Avatar
ill keep it simple, if you want super elaborate, then PM me.
do use the direct setup. dont tap into your stock fuel system. i mean, you can if youd like, but i would never suggest that.
run a standalone fuel system, 1 gal cell, holley regulated pump, and do the aluminum lines for the fuel yourself. all under the hood, nice and clean.
biggest reason is, you have octane on demand when you do this. so aside from the safety of not robbing the rail, you can run leaded fuel, say VP import, C16, or late model plus. and you get not only the octane boost/lead, but you get top cyl lubricants also.
and since you want to run top end, runs/roll ons. make sure you go 2 steps colder plug, instead of 1.
more safety items. run a wideband gauge, and EGT gauge. first few pulls, 5-7 tenths of a mile, try and shoot for high 10's say 10.8 AFR, and then do a plug check. from a 60 roll, you should be able to pull off 160 mph, in 17-20 seconds.
if your EGT starts going over 1300, watch close, and dont let it get higher than 1600 F. if so, back out. you can prob go as lean as 11.4 afr, but thats pushing it.
if it were 1/4 mile, ok, but youll be in it for a long ways, and dynamic cyl pressure goes up, and so do cyl temps. raising the chance of preignition. or detonation.
as for the window switch, i like to spray low, but i can build my own motor. so for your safety, id say dont window any lower than 3500 rpm. and shut it off 300 or so before fuel cut. if your ap1, window at 8900, if your ap2, window at 8000.
have fun owning people. let me know if you need any help. laters dave
p.s get drag radials. you will have traction issues.
Old Sep 26, 2007 | 01:35 PM
MR2S2K's Avatar
No offense, but after reading what you wrote, and how you wrote it, based on the number of days you've been on here you probably just got your car and is in the younger generation. NOS is "affordable" horse power when you need it but still requires a fair resonable amount of research and homework.
As s2000nvegas mentioned, he from his experience with NOS, knows quite a bit of knowledge. His route maybe the most safe and reliable/piece of mind operation of running nos, however you need to think about which way you want to go with FI. See how much you want to spend, and do it the right way from square one, rather then risk your motor doing it the wrong way.
Im not a big fan of NOS, but it is a reliable and affordable source of power. Good luck with which ever way you go, and welcome to the board.
Old Sep 26, 2007 | 09:16 PM
none taken...ive heard about s2ki.com a while bakc but never registered because i never realli had a reason (since not owning the s2k yet)...n yea ive had the car about 6months but im taken it over from my brother whos had it a few years...i do know a litto due to helping installing dry kits on d-series and b-series engines, and hearing from other s2k owners that dry shots isnt for our cars so i thought ide research about it (onli a few months now) ...
but yes newaiz, s2000Nvegas thats very helpful info...im guessing your runnin NX?
schhim
Nov 20, 2015 09:10 PM
hondaguys2k
15
Mar 16, 2011 05:36 PM
1point3_to_2point2
Mar 11, 2010 07:32 AM
street_ruler
Jun 13, 2009 07:13 AM
s2knky
Sep 16, 2007 04:50 PM
