Noise from engine on my turbo
Old Sep 18, 2009 | 08:44 AM
Irishflame27's Avatar
sounds like piston slap........
Old Sep 18, 2009 | 12:17 PM
Rajdlos's Avatar
so... today we installled the oil cooler and the presurre is: idle 20-25psi, at 3000rpm only 48-51 psi.
I REALLY NEED THE HIGH VOLUME OIL PUMP :-( Can you help me, where can I find it?
btw. VTEC not run
and you have true, Its looks on piston slap, maybe piston pins :-/
Old Sep 18, 2009 | 12:24 PM
Rajdlos's Avatar
and btw. is the piston slap destructible for the engine? I mean, if i can drive slow with this damage, im affraid of cylinder walls, that they will be scored
Old Sep 18, 2009 | 08:15 PM
Kirpich's Avatar
Try not to put that 20W60 weight oil in. It's totally not recommended. That's _not_ how to fix low oil pressure. Looks like there are other problems to loot at first.
Seems like there's an opinion forming here about the pistons. You need to look at that issue first. While doing it, take a look at the oil pump. If possible, take it off, re-measure it, all clearances, wear limits, etc., according to the repair manual. Maybe your engine needed a rebuild because of bad oil pump causing oil starvation, and ruining the engine in the first place. Just my theories.
Old Sep 18, 2009 | 10:41 PM
Rajdlos's Avatar
We changed the oil yesterday for Motul V300 10W40, and still same problem.
The oil pump is new, but I red, that still problem with low oil press have many peoples here.
I mean that oil pump is in good condition, but we disconected oil relocation filter and turbo, oil press was 80psi-85psi.
Old Sep 18, 2009 | 10:50 PM
Rajdlos's Avatar
http://www.importperformanceparts.net/impo...pumpshonda.html
have someone experience with this pump??? They make HV oil pump only for AP2, but I tahink, that pump is same.
Thanks!!
Old Sep 19, 2009 | 06:30 AM
03BlkS2k's Avatar
are the valves adjusted within spec?
Old Sep 19, 2009 | 12:41 PM
AndyFloyd's Avatar
The engine sounds noisy. I was just making a guess about the pistons but it sounds like the engine is a little loose. You know low oil pressure could be caused by bearing clearances within the engine as well. You all didnt run oversize bearings for rods or mains did you?
My old miata with a built engine always had lower oil pressure ( it was built loose ) which is what you want if you beat on the car a lot because if its loose when its warm its tight make sense. Anyways, I would also adjust your valves as well and check to see if they are out of spec. If I recall exhaust is .10 and intake is .09". Might wanna check on that. Also wiseco isnt a piston I love since it slapped a lot on my BP miata engine...that could be what you hear. Good luck man.
Old Sep 21, 2009 | 11:30 AM
Rajdlos's Avatar
03BlkS2k: yes stock clearence
AndyFloyd: yes you have true, problem will be in bearings, main or rod, they leak oil press. We must rebuilt the engine :-( The noise is from TCT, cause o low oil press.
Stine
Jul 13, 2011 03:48 AM
unbreak_s2k07
Aug 22, 2009 02:58 PM
wright_now
Dec 8, 2008 04:56 PM
AusS2000
Nov 28, 2006 08:02 PM
fromSStoS2
Sep 15, 2004 11:20 AM
