normal for o2 sensor to idle at 10.1 AFR?
Old Jan 9, 2011 | 06:01 PM
vietdragontekx's Avatar
Default normal for o2 sensor to idle at 10.1 AFR?
was looking at my O2 #1 AFR on AEM EMS power tuner problem with the car idling and it show 10.1, is that a normal reading?
Old Jan 9, 2011 | 06:43 PM
Deception's Avatar
if your sensor is accurate, then its really rich at idle.
When had RC injectors, anything higher than 10.5 , sometimes 12 AF at idle would misfire. When I got ID injectors it idled at 14.5-16 without issue.
Old Jan 10, 2011 | 03:33 AM
Spec_Ops2087's Avatar
I idle and cruise out of boost around 13.5. 10 is stupid rich.
Old Jan 10, 2011 | 09:15 AM
s2000Junky's Avatar
Yeah fuel wash rich. Idle target should be 14.7. It will normally sweep between low 14's and mid 15's. If your idling under 14 your wasting fuel.
Old Jan 10, 2011 | 09:33 AM
S2000_FUN's Avatar
You can idle also above 14 but at least in my car at 14.5 that it was at the beginning it was missfiring at idle.
Old Jan 10, 2011 | 09:34 AM
s2000Junky's Avatar
Crappy injectors and or too low of an idle pressure to get proper atomization.
Old Jan 10, 2011 | 09:57 AM
KwikyMAN's Avatar
i can't think of a time you would ever wanna hit 10:1....lowest i would ever go is 10.8:1 A/F....
Old Jan 10, 2011 | 10:01 AM
FullBlown's Avatar
Former Sponsor
Is it calibrated correctly on the AEM? Do you have a gauge or just an inline wideband?
Old Jan 10, 2011 | 10:20 AM
s2000Junky's Avatar
Old Jan 10, 2011 | 10:30 AM
itlynstalyn's Avatar
What injectors are you running? My RC550's idle at around 12.7-13.5 at times. It's pretty annoying.
