not bad for only reving to 6 grand...
Originally Posted by chairmnofthboard,Apr 8 2007, 10:23 AM
aftermarket oil cooler? I thought the presure would be more consistant with the higher RPMS? Do you plan on going over 6500?
the problem with the cooler is the lines the more line the less pressure. I just want to eliminate any way I could lose pressure
Originally Posted by GDM S2K,Apr 8 2007, 10:41 AM
yup this week im hoping to get back on the dyno.
Your engine in a span of 1300 rpms (5200 to 6500) adds 190 ft lbs torque and 265 rwhp. That is absolutely going to rip the tires.
My supercharged engine goes up 27 ftlbs and 75 rwhp in the same spot.
If the boost allows the engine to continue up like that to over 9000 rpm you will be in the 750 to 900 rwhp range. What is the displacement of your engine?
2.0 stock size pistons. a buddy on a b series made 777@33 pounds our motor is so much more efficiant than the B series that I should be closer to 800@ that psi. not to mention my head is ported like a mofo
Do you have a oil pressure gauge?
Since I am running built motor, turbo with guages everywhere. Just curious on your tune did you see a oil pressure drop?
Originally Posted by Raven628,Apr 8 2007, 02:06 PM
What size oil lines were you running to your cooler? Dash 10?
but hotter oil temps (espically in the summer) will yield more of a pressure drop than the oil cooler....i think its worth it to have it on there, unless you dont mind cooking your oil and changing it every 1k miles or so. . .
ssjmikeg
Oct 1, 2009 03:16 PM
05YellowEVO8
May 30, 2007 04:39 AM
yellowknockers
Nov 6, 2005 07:33 PM
