Not your normal overheating problem....or is it?
Old Oct 10, 2014 | 02:00 PM
s2klariat's Avatar
Another vote for jacking the front of the car up. Also, do NOT open the bleeder valve with the engine running. It took me a while to get the hang of the bleed process when I flushed my coolant earlier this year.
Old Oct 10, 2014 | 06:56 PM
KaNgArOo's Avatar
Well pressure tested the system, and its not holding pressure. Hmmmm
Old Oct 10, 2014 | 09:36 PM
riceball777's Avatar
Bad radiator cap?
Old Oct 11, 2014 | 04:50 AM
Redline S2K's Avatar
When you pressurized the system, how long before the pressure dropped?
Old Oct 11, 2014 | 06:06 AM
KaNgArOo's Avatar
We tested it with the radiator cap off. So its not the cap. It was losing 1psi every 15min
Old Oct 15, 2014 | 05:52 PM
SlowTeg's Avatar
Any luck bleeding the system? Hopefully you didn't pop a headgasket now that you're losing pressure..
Old Oct 15, 2014 | 06:09 PM
KaNgArOo's Avatar
Bled the system. Its holding steady, but havent check the head gasket yet. Pretty sure its the head gasket though. I will update when I find out?
Old Oct 15, 2014 | 08:05 PM
baZurk's Avatar
240 is pretty f'in hot. What kind of overflow container does this radiator use?
Old Oct 16, 2014 | 06:07 AM
KaNgArOo's Avatar
It doesn't have a overflow tank.
Old Oct 16, 2014 | 08:44 AM
baZurk's Avatar
What? It has to have something.
