Novi 1000 low boost
Old Jun 15, 2018 | 08:32 AM
S2K Ken's Avatar
Default Novi 1000 low boost
Need some advice about my comptech setup if any of you guys have had simialar experiences. I'm running a novi 1000 with a 3 in pulley and a fmic that was included when I bought the kit used. Was hitting 10-11 psi back in april but I just checked my datalogs from my trackday yesterday and was only hitting 8 peak. Its not belt slip as I recently put on a new gatorback belt and adjusted the tension before heading to the track. Checked all my intercooler piping and its tight. In thinking either the blowers on it's way out(overspinning it with the 3 in pulley) or the summer heat is lowering the boost. Anybody else seen lower psi during the summer?
Old Jun 15, 2018 | 02:39 PM
AP1Chief's Avatar
Send me a Log
jmpaintcorrection@yahoo.com
Most likely its just the DA effecting it.
Old Jun 15, 2018 | 02:47 PM
EOE's Avatar
EOE
Originally Posted by AP1Chief
Send me a Log
What's DA?
Old Jun 15, 2018 | 03:04 PM
S2K Ken's Avatar
I'll send the logs as soon as I get home. But what is a DA?
Old Jun 15, 2018 | 03:16 PM
AP1Chief's Avatar
Lol the density altitude.
Old Jun 15, 2018 | 03:20 PM
S2K Ken's Avatar
ohhhhhh makes sense now sending my logs now
Old Jun 15, 2018 | 03:26 PM
AP1Chief's Avatar
cool
Old Jun 16, 2018 | 05:55 AM
markforrester99's Avatar
Dirty air filter can also cause boost drop. I thought i had a problem with belt slip on my HKS kit as it tailed off at the top of the rev range. Fitted new air filter and i got 2psi back.
In my experience if you do suffer belt slip you wont hear it, its normally silent and only real way to see if it is slipping is to really crank the tension on.
Old Jun 16, 2018 | 11:39 AM
soulicious's Avatar
A new belt will slip and will need re-tensioning after it breaks in a little bit.
Old Jun 16, 2018 | 12:54 PM
S2K Ken's Avatar
My air filter is fairly new too. Looking at the logs the bosst is low throughout the powerband not just at high rpms which would indicate slipping. Im aware of new belt stretching often and check the tension quite often.
branden2k
Nov 5, 2013 06:49 PM
vadik_s2k
Aug 11, 2011 11:42 AM
s2kmast
Jul 15, 2011 09:41 AM
kylemonster85
Jun 11, 2007 10:26 AM
red01
Oct 8, 2005 06:05 AM
