Which OEM coils are the best?
Old Apr 11, 2011 | 04:50 PM
  #21
06S2k07Si's Avatar
Originally Posted by RedLineS2k10
Get k24 coil packs, its the same ones okada sells bu they just put their label on it........Okada coil packs are actually denso's, and all they did was use a TSX coil pack and put it in a s2000 for a higher pulse width.....Look at tsx coils and check the product # and ill compare that # with my okadas and i gurantee their the same. Be cheaper then buying $600 okadas and getting OEM tsx coils which r the same thing.
Really?...sounds too good to be true!
TSX part number is: 30520-PNC-004 ($73.31 ea) http://www.acuraoemparts.com/delray/...All&vinsrch=no
Brian
Old Apr 11, 2011 | 06:43 PM
  #22
AFs2k's Avatar
Hmmmmm...
Old Apr 12, 2011 | 09:53 AM
  #23
red@9k's Avatar
can anyone confirm this?
Old Apr 13, 2011 | 03:50 AM
  #24
boostedf22c's Avatar
Gap the plugs down? He try that yet. A lot of the time that'll solve a spark blow out issue.
Old Apr 13, 2011 | 08:09 AM
  #25
D1sclaimer's Avatar
How many miles have you put on your AEM pencil coil CDI setup?
I'm frustrated with mine. The epoxy holding them together have come off on 2 of the coils and dropping cylinders.
Old Apr 13, 2011 | 07:47 PM
  #26
I'd say about 4000 miles or so?? I haven't had any issues like that. For some reason though, I thought there were 2 versions of the coils. You might want to give AEM a call and see what they say.
Old Jun 8, 2011 | 09:00 PM
  #27
joefish1298's Avatar
Has anyone thought that perhaps the AP1 coils cost more and have a different non-superseded part number is because they need to support sparking at much higher RPM?
Sure maybe you can plug AP2 coils into an AP1 and get spark but that doesn't mean they're as good as or better does it??
Old Jun 13, 2011 | 03:44 PM
  #28
red@9k's Avatar
So has anyone tried using the k24 coil packs from the 04-08 tsx?
Old Jun 14, 2011 | 07:07 AM
  #29
MasterForce's Avatar
still waiting for someone to confirm this. if so im getting them
Old Jun 14, 2011 | 10:22 AM
  #30
DFWs2k's Avatar
If i had any spark issues i would throw in gfs coilpacks (06 tsx) but i don't
Anyone local (dfw) have the okadas and spark issues?
