OEM intake mod
Old Feb 27, 2019 | 11:06 AM
Rss2k's Avatar
Question OEM intake mod
So I have been doing research on cold air intakes. The one pictured below has great reviews but it seems like if I just remove the cover on my OEM intake it is pretty close to the same thing. Am I missing something?
Another question is if I decide to go supercharger am I going to have trouble passing smog in Cali? It looks like the SOS stage 2 would be my choice
Thanks.
Old Feb 27, 2019 | 12:05 PM
Chuck S's Avatar
Removing the air box cover will increase noise and decrease power. Even the Might Car Mods lads demonstrated that years ago. Search for the LHT airbox modification. It's better in this respect.
Is there such a thing as a CAFE approved supercharger? Plenty of guys in California have them I'm sure but not sure how they pass smog. The aftermarket ECU you'll need is probably certified "for of road use only" as well.
-- Chuck
Old Feb 27, 2019 | 02:24 PM
alSpeed2k's Avatar
No, K&N intake is supposed to sit tight against the hood, minimizing the heat soak (although people have noticed heat soak, especially in the hotter climate; I didn't have that problem). Removing the airbox leads to major heat soak, you'll notice it right away, even in moderate weather.
Old Feb 27, 2019 | 05:02 PM
noodels's Avatar
Yes
& ffs !!
Old Feb 27, 2019 | 07:12 PM
spdracerut's Avatar
Thanks.
Removing the stock airbox lid will suck in a lot of hot air coming off the radiator and significantly reduce power.
https://motoiq.com/project-s2000-par...oing-faster/3/
Data on air temp coming off radiator:
https://motoiq.com/project-s2000-par...ers-and-vents/
Old Feb 27, 2019 | 09:04 PM
Rss2k's Avatar
Thanks, great info.
Old Feb 28, 2019 | 07:59 PM
soulicious's Avatar
You're not going to pass smog with an SOS S/C kit since it's not CARB legal. You'll need to remove part of the kit and hook up the vacuum lines back to stock to pass the visual.
Old Mar 1, 2019 | 11:31 AM
Rss2k's Avatar
Thanks for the info.
cottoncandyek
Southern Ontario For Sale
Apr 15, 2014 06:34 PM
kew2k
Sep 12, 2013 05:05 PM
lucky666
May 2, 2011 01:35 PM
ebchu
Nov 5, 2008 07:30 AM
campbuds
Oct 6, 2005 07:29 AM
