Oil Buildup On Comptech Blower
Old Nov 9, 2005 | 07:32 PM
folex187's Avatar
Default Oil Buildup On Comptech Blower
I took the pipe off that goes from the intake box to the Paxton unit. When I took it off I noticed that there was a black build-up before the impellar. I whiped it away and it appears to be oil.
Is this normal or is it coming from the breather line that goes into the intake tube?
Old Nov 10, 2005 | 05:49 AM
Venomous S's Avatar
Maybe could it be if you oiled your air filter, the charger sucks it in?
Old Nov 10, 2005 | 08:25 AM
SIIK2NR's Avatar
I had the same thing when I looked at mine. It wasn't much so I assumed it was from the air filter oil that consolidated there. When I cleaned the filter I sprayed the filter pretty vigorously so I can see how it would be easy for it to deposit there.
Old Nov 10, 2005 | 08:41 PM
AusS2000's Avatar
I think you'll find it came down the pipe from the valve cover breather. I believe the SC sucks it down. I had it with my SC and as my turbo is set up the same way it also happens now. Intention is to put a catch tank inline.
red01
Dec 28, 2007 11:19 AM
SIIK2NR
Oct 7, 2005 04:22 AM
AusS2000
Aug 26, 2003 06:37 AM
nookie4everyone
Mar 26, 2003 07:36 AM
