Oil in charge pipes
Old Jul 17, 2006 | 02:07 PM
ex-eclipse's Avatar
I will check for kinks or obstructions but I doubt it, there really isnt anything else in that area. Does this look ok for return location:
Old Jul 17, 2006 | 03:22 PM
Slows2k's Avatar
I'd want the return a bit higher, as there is liquid oil in the pan at that height.
Old Jul 17, 2006 | 03:31 PM
ex-eclipse's Avatar
I do think I can get it much higher than that?
Old Jul 17, 2006 | 03:38 PM
Slows2k's Avatar
Many have tapped the block's girdle, directly above the pan rail.
Old Jul 17, 2006 | 03:40 PM
Slows2k's Avatar
The girdle is tapped in this one:
Old Jul 17, 2006 | 04:49 PM
ex-eclipse's Avatar
I guess I might have to do that if this keeps up. Thanks for the advice.
Old Jul 17, 2006 | 08:30 PM
herecomesboost's Avatar
Your oil return should be high enough as it is right now (high on the oil pan). I suspect your seals gave way early. How do you have your oil feed return mounted? Meaning, are the feed and return openings on the center cartridge exactly perpendicular with the ground? Any more than 30 degrees from perpendicular and that could cause the seals to fail (due to oil backing up in the center cartridge.)
Kyle Ritchie
Old Jul 18, 2006 | 02:39 AM
ex-eclipse's Avatar
They are not straight up and down. Not even close, the manifold design does not allow for them to be since the four bolts from the turbine frame are directly below the center cartridge.
Old Jul 18, 2006 | 02:47 AM
ex-eclipse's Avatar
Here you can see the angle of the return. I think it is under 30* still though. You cant really see it in the picture but there is a 45* peice threaded into the turbo that the AN line screws on to and then angles back.
Japmuscle
May 31, 2013 08:47 AM
seoul2k
Apr 26, 2011 04:40 PM
Mijae007
Apr 19, 2011 06:43 PM
ChefJ
Aug 5, 2010 01:46 PM
Ap2spoonf20c
May 29, 2010 01:52 PM
