Oil feed flange question.
Old May 9, 2008 | 05:42 PM
sIIooo's Avatar
Default Oil feed flange question.
Hey everyone this is the oil feed flange that I got with my oil feed kit is this hole big enough to squirt oil through or should I drill it out bigger? It is a garrett t3/t4 btw. Thanks guys.
Old May 9, 2008 | 10:15 PM
skibum's Avatar
On the inline kit, the oil feed line screws right in to the turbo and is about 1/4"
Old May 10, 2008 | 05:33 AM
PeanutButter's Avatar
can we see the other side of that thing?
look like a horrible excuse for a restrictor
Old May 10, 2008 | 08:00 AM
sIIooo's Avatar
Here is the other side I'm thinking that if the hole is to small I can just drill it out to the size of the hole on this side.
Old May 10, 2008 | 08:05 AM
its called a restrictor, its for ball bearing turbos.
Old May 10, 2008 | 09:05 AM
sIIooo's Avatar
So do you think if I drill out the hole it will work ok for a non ball bearing turbo.
Old May 10, 2008 | 11:09 AM
ERL_S2000's Avatar
Just buy the correct part.
Old May 10, 2008 | 12:18 PM
sIIooo's Avatar
any suggestions on where to buy them?
Old May 10, 2008 | 12:27 PM
sIIooo's Avatar
So I called found out that I can just screw a fitting directly into the turbo so I am just going to do that.
seoul2k
Apr 26, 2011 04:40 PM
Ilike2DRIFT
Aug 24, 2010 10:12 AM
skool u
Jun 4, 2009 09:34 AM
XclusiveAutosports
Oct 2, 2006 07:57 AM
herecomesboost
Jun 8, 2006 08:05 PM
