Oil feed and water lines
Old Mar 2, 2010 | 07:40 AM
Dr Jekyll's Avatar
Default Oil feed and water lines
I piecing together a turbo kit and i need some oil and water lines, the turbo is a BB T60, so it is oil and water, i have heard that i dont need to use the water part but i would like to. so, where do i get the oiil feed from and where do i get the water feed from?, and also what kind lines should i get, size, and what about a a oil restrictor?
thanks in advance guys.
Old Mar 2, 2010 | 08:10 AM
Dr Jekyll's Avatar
here is a pic of the turbo BTW, ill post some better ones when i get home
Old Mar 2, 2010 | 04:48 PM
Dr Jekyll's Avatar
any one?
Old Mar 2, 2010 | 07:28 PM
pwrofdrm's Avatar
Here you go:
http://www.stealthmodeperformance.com/oil.shtml
http://www.honda-tech.com/showthread.php?t=1902396
Old Mar 3, 2010 | 12:27 PM
EngineerX's Avatar
Try ATP Turbo, they have a -4AN restrictor.
http://www.atpturbo.com/mm5/merchant.mvc?S...tegory_Code=BCS
According to ATP it uses the same restrictor I used for my GT30 ( http://www.atpturbo.com/mm5/merchant.mvc?S...&Category_Code= )
You can then make your own steel braided -4 AN hose and source the oil from the OEM oil pressure gauge port or if you are using an oil filter relocation adapter you can use one of the adapter's 1/8 npt gauge ports.
ATP Turbo also sells -6AN banjo fittings.
Steel braided lines work nice around the turbo high-heat area
http://www.atpturbo.com/mm5/merchant.mvc?S...tegory_Code=GRT
ATP sells most stuff you need for your turbo setup.
For your reference, check out these pics at bottom of this post:
https://www.s2ki.com/forums/index.php?showt...post&p=16368685
Good Luck
Spec_Ops2087
Apr 28, 2010 04:18 PM
Ap2spoonf20c
Feb 18, 2010 08:21 AM
Silver S2k4
Feb 21, 2008 01:14 PM
SoCalIsMyLife
Mar 4, 2006 06:17 AM
fperra
Aug 5, 2003 03:26 PM
