Oil and Water Lines
Old Mar 1, 2006 | 08:37 PM
SoCalIsMyLife's Avatar
Default Oil and Water Lines
I'm looking for oil and water lines and fittings for my TD06/T04 60-1 HIFI turbo. TD06 is pretty much the equivalent of a T3. Do I need 3AN or 4AN for oil inlet? What about a restrictor? Also, I'm pretty sure I need 10AN for the return line right? My turbo will sit right next to my engine, like timg's. I'm guessing 18"?
I know braided will be better for the return line, but I heard from ATP that 5/8" reinforced silicone tubing will work as well. Any opinions on that? Also, what size water lines and lengths do you recommend?
Old Mar 2, 2006 | 05:56 PM
Old Mar 3, 2006 | 01:47 PM
ex-eclipse's Avatar
Nobody knows what set up you have or where about you are running the water lines. Use a string, coat hanger, or even the HOSE and measure it out before you cut it. Also I wouldn't use rubber hose for anything with oil in it even though the return line isn't under pressure.
Old Mar 3, 2006 | 04:20 PM
hmmm well filter relocation kits usually use silicone hose... or is it rubber
i.e. the Ultimate Racing relocation kit
I figured out 1/2" ID hosing for coolant should be good enough.
hmm... so 3AN or 4AN?
Old Mar 4, 2006 | 06:17 AM
Please someone tell me if I need 3AN or 4AN. I need to order the stuff this weekend. I've already stated what turbo I have above. What other info do you need?
s2k16803
Apr 9, 2012 08:52 AM
bamboosted
Jun 9, 2011 10:55 AM
Spec_Ops2087
Apr 28, 2010 04:18 PM
Dr Jekyll
Mar 3, 2010 12:27 PM
Ap2spoonf20c
Feb 18, 2010 08:21 AM
