oil filter relocation kit
Old Aug 13, 2012 | 04:06 PM
neoleooo's Avatar
Default oil filter relocation kit
I installed a Full-Race prostreet turbo manifold and having trouble finding an oil filter relocation kit that will work with this manifold. Most of the kit have plates that are too thick and/or the fittings sticks out and hit the turbo. Will someone please recommend me an oil filter relocation kit that will work with the Full-Race manifold. Thank you!
Old Aug 13, 2012 | 04:18 PM
herecomesboost's Avatar
Are you also removing the factory oil cooler?
Old Aug 13, 2012 | 04:31 PM
wildkart's Avatar
Canton oil filter relocator, the fittings come out the sides.. Depending on the turbo, you will have to cut to block a little to make it fit.. I run the same manifold, with a precision 6266..
Old Aug 13, 2012 | 04:42 PM
neoleooo's Avatar
yes i am. is that a good idea? im planning to use an after market oil cooler so i can relocate it elsewhere
Old Aug 13, 2012 | 04:43 PM
neoleooo's Avatar
where can i get the Canton oil filter relocator?
Old Aug 13, 2012 | 05:08 PM
http://www.summitracing.com/parts/CTR-22-597/
Old Aug 13, 2012 | 06:08 PM
CRXsir29's Avatar
i used the full race oil relocation kit with this set up
Old Aug 14, 2012 | 09:44 AM
neoleooo's Avatar
thanks guys for your help!!
Old Aug 14, 2012 | 09:52 AM
wildkart's Avatar
Full race uses the Canton... or it is exactly the same..
Old Aug 15, 2012 | 02:02 PM
neoleooo's Avatar
so pretty much part# 22-597 and 22-620 from summitracing.com is all i need?
